VS 7 SE - DVD burn problem
tedkord
Post by tedkord »
Hi, all...
I'm new to burning DVDs, and I'm using VideoStudio7 Se that came with
my burner.
I'm trying to burn two episodes of a TV show that I recorded on my
computer. They're recorded in xVid codec.
Twice now, I've burned a DVD with both episodes. VS7 SE converts
the video stream perfectly, but the second episode had no sound both
times. The .avi file has sound.
I burned them by choosing SHARE/CREATE DISK/DVD, then adding
video - both files. The only change I made was to choose custom
compression, bringing the compression up to 6900 kbps, as high as
I could get without going over the DVD free space.
What am I doing wrong? Any help is appreciated.
THoff
Post by THoff »
What country are you in / what TV video standard do you use locally? What audio format did you use when creating the DVD? Does the DVD play with audio on your PC?
tedkord
Post by tedkord »
THoff wrote:What country are you in / what TV video standard do you use locally? What audio format did you use when creating the DVD? Does the DVD play with audio on your PC?
Hi, thanks for the reply...
I'm in the US/NTSC. I used LPCM, which was the default when I
opened the program. I tried to set it for MPEG on the next burn,
but it just reset to LPCM each time.
The .avi file plays with sound on my PC, but the DVD does not.
(The second episode, that is. The first has sound)
