Duration seems very straight forward and very simple but I am having a problem with it in VS v11+. When I set a transition, there are naturally quite a few, I want to set the duration of each to 8 seconds. I click on seconds and use the up arrow to increase from the default to 8. Sometimes it will go up but a lot of time it will not. In all cases I can get to 4 but no further.
I tried typing 8 instead of using the up arrow but that makes no differance. Any suggestions?
Changing Duration
nocam
- motherboard: Intel Corporation D850EMV2 AAA87987-401
- processor: 2.53 gigahertz Intel Pentium 4
- ram: 1GB
- Video Card: Nvidia GeForce7950GT AGP512MB+256BIT+DDR3+Dual-DVI
- sound_card: Creative SB Audigy
- Hard_Drive_Capacity: 400
- Monitor/Display Make & Model: Samsung SyncMaster (19.1"vis, s/n HVBLB0
Re: Changing Duration
the maximum length of a transition cannot exceed the length allowed for it by the length of the adjacent clips/photos - if you can only set 4 seconds it suggests to me that one of the clips adjacent to it is less than 4 seconds - or you have a transition each end of a less than 8 second clip- if you wish to use a longer transition your clips must be longer. A transition effectively overlaps the video/photos by the length of the transition - so if there is insufficient length you cannot increase the transition time.
Rather than changing each transition individually why not set the default before you insert them - open ''preferences" (press F6) -and select the 'edit' tab at the top - near the top you will then find the option to set the default duration time.
Bushdoctor
Yes, what BrianCee said.
I would like to add that transitions between 2 files requires each of those files to be at least half the length of the transition.
So, if you want to apply a crossfade of 8 seconds between 2 pictures, each picture needs to have a runtime of at least 4 seconds.
Basically, if you're out of space for the transition to visually overlap the picture or video it can't be made any longer.
8 seconds on a transition is quite long though, but I usually create slideshows. What's your project about?
Good luck!
Bushdoctor
Good luck!
Bushdoctor
nocam
- ram: 1GB
Thanks Ken and Brian,
I think I understand it but as I play with it I find it is a little tricky. I am new at this so thanks for mentioning the 8 second transitions being to long. I have reduced them back to 6 seconds and will probably find that to long. I am transitioning intermittently between some images and video clips of my wife around Hong Kong. Where do you guys learn these little details?
12 years of using VideoStudio and eight years on these forums help a lotnocam wrote:Where do you guys learn these little details?
