Hi all, I'm running Paint Shop Pro X. I create a 100x100 pixel JPG using only black and white, then use Alt-L->M->M to collapse down to a single layer, and save the file. When I reload the picture, the black and white are accompanied by several pixels in varying shades of grey. I'm guessing it's trying to apply an anti-alias effect when I load the image but I'm not sure. I've looked through the preferences but haven't found anything. How do I set PSP so it only saves/loads exactly what I created without changing any pixel colors?
Thanks,
Dennis
Artifacts added to my JPG files, why?
dennis1960
- processor: AMD Turion 64 X2
- ram: 4GB
Joelle
- motherboard: Asus Prime B350M-A
- processor: AMD Ryzen 5 1500 Quad-Core
- ram: 16 GB RAM
- Video Card: NVidia GeForce GTX 1050
- Hard_Drive_Capacity: 1TB
- Monitor/Display Make & Model: Samsung
- Corel programs: PaintShop Pro X9
Re: Artifacts added to my JPG files, why?
Oh my, have never come across that problem before.dennis1960 wrote:Hi all, I'm running Paint Shop Pro X. I create a 100x100 pixel JPG using only black and white, then use Alt-L->M->M to collapse down to a single layer, and save the file. When I reload the picture, the black and white are accompanied by several pixels in varying shades of grey. I'm guessing it's trying to apply an anti-alias effect when I load the image but I'm not sure. I've looked through the preferences but haven't found anything. How do I set PSP so it only saves/loads exactly what I created without changing any pixel colors?
Thanks,
Dennis
This might sound odd, but why do you use those keyboard shortcuts?
Alt-L is Colorize.
I have no idea what the additional M>M does.
Why not right-click on the Layer in the Layers Palette and select Merge>Merge All.
When you re-open the file it will open exactly as you saved it
When you save, what compression factor are you using? Maybe that affects the result.
I save Jpgs at a compression of 6.
The default is 20, but I find that too high.
Another thought: Are you re-opening the Jpg file work on it, then save it again, re-open etc? That would lead to loss of quality.
Joëlle
Joëlle
(PSPX9 )
(PSPX9 )
dennis1960
- ram: 4GB
On my version "Alt-L" pulls down the Layers menu, "M" opens the merge submenu, "M" flattens all...I love keyboard shortcuts
Oddly enough, I tried saving the image as a .gif and reopening and I get exactly what I saved with no artifacts...but saving as a .jpg gives artifacts...
I'll give the compression a try and see what happens...
dennis1960
- ram: 4GB
Yup, lowering the compression fixed the problem, Thanks
Joelle
- ram: 16 GB RAM
dennis1960 wrote:Yup, lowering the compression fixed the problem, Thanks
Excellent
Joëlle
Joëlle
(PSPX9 )
(PSPX9 )
