Request to check tool/brush action.
brucet
operating_system: Windows 8.1
Post by brucet »
Before I add a 'bug' issue to the above thread could some one please check the following thanks.
PSPx5.
Tools.
Smudge Brush.
Size 40. Doesn't matter what size.
Hardness 100. Doesn't matter hardness setting.
Step 1.
Density and Thickness 100.
Rotation 0.
Opacity. Here's my problem. If I set it to 71 or below nothing happens. If I set it to 72 or higher I get a big smudge. I can't get an opaque smudge. 72 I get nothing and at 73 I get a lot of smudge. I can go with a higher setting ok but I can't get anything below 72.
I can play with density but that' gives a different result. Not what I want.
Thanks.
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: Request to check tool/brush action.
Post by LeviFiction »
Smudge works just fine for me.
Have you tried resetting the workspace?
brucet
Post by brucet »
Thanks.
It was working just fine.
Work space is ok.
I tend to believe it's a memory issue. If I use it too much it has problems. If I turn off x5 and do a restart all is fine again.
regards
teknisyan
processor: Intel Corel i5
ram: 4 GB
sound_card: Realtek HD Audio
Hard_Drive_Capacity: 500 GB
Post by teknisyan »
Have you installed the PSP X5 Sp1? If not then you can download it at -- http://www.corel.com/corel/pages/index. ... id=5000003
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
brucet
Post by brucet »
Thanks Abiel. I have Sp1 installed.
The problem keeps re occurring. The Smudge tool/brush will work fine for awhile then it will not work at all below an Opacity setting of 71. (Anything over 71 is too harsh for my work). The fix is to quickly change tools and start again. It's as if there is a memory issue and once memory/cache is full then nothing will work. I have left it for a while to see if it will catch up but it doesn't. Only by a change of tools and coming back to the Smudge tool/brush can I continue. It's a pain but not the end of the earth.
regards
Joelle
ram: 16 GB RAM
Hard_Drive_Capacity: 1TB
Post by Joelle »
It works fine here - X5Sp1.
I use the Smudge Brush quite a bit, so have added it to the Tools Bar.
Joëlle
Joëlle
(PSPX9 )
