color correction tool: revert to default settings
Bugs & Suggestions
datenhamster
Post by datenhamster »
Hi there!
I found that the color correction tool (the one where you can shift Hue, brightness and so on for a color range) does not revert to default when double-clicking the sliders or the color box/circle.
And there is another issue with that tool. I had a very dark sky (used a pol filter too heavy) which i tried to correct. When using the pipette to get the color (dark blue) and then changing the values for brightness, it lightened the lower, lighter part of the sky while leaving the dark part as it was. So this behavior was contra productive.
It would be a very nice thing if you can fix that.
best regards,
Martin.
