Fade to black in VS Pro X4
Mrflooglebinder
ram: 8gb
Hard_Drive_Capacity: 500
Post by Mrflooglebinder »
When using fade to black in the options panel there is an option to select color. So I could use fade to white etc i spose. This option is grayed out though. Does anyone know how I can activate this?
AussieTX
motherboard: Gigybyte 990FXA-UD3
processor: AMD FX8350
ram: 16 Gig
Video Card: Assus HD 7770 2GB GDDR5
sound_card: On Board Audio
Hard_Drive_Capacity: 2 T
Monitor/Display Make & Model: Asus 23" IPS + Acer 23" IPS
Re: Fade to black in VS Pro X4
Post by AussieTX »
Maybe it only goes to Black cause it is called "Fade to Black"
Drag a few seconds (or as long as you like) of the colour you wish to fade to and place it after the clip. Then select the cross fade transition between your last clip and the colour.
Jack of all trades,
Master of none!
Mrflooglebinder
ram: 8gb
Thank you for stating the obvious re "fade to black".
Also thanks for the advice seems to work ok.
