I have just done a quick series of tests using various output formats on a one minute project made up of top quality 16:9 AVCHD video, 25 fps, 1920 x 1080i Upper Frame First. I achieved the lowest size x best quality (though small screen) output using XVid set using the 1280 x 720 option set for single pass. It produced an output video of 22 MB for that one minute.
To access the XVid codec in VS X5 (once you have installed the codec), you go to Share > Create Video File > Custom, then select .avi as the output format. Click the Options button, and on the third tab (labelled AVI), you click on the drop down menu marked Compression at the top and select XVid from the list of available codecs. Then below that is a Configure button. When you select that a new dialogue box appears, and you then click on 'Profile @ Level' and select XVid HD 720 as the output. In the next window, leave the default at Single Pass. Click Ok and Ok to close those dialogue boxes. Give your new file a name in the original Share dialogue box, and then click Save. The conversion will start and is fairly fast for such a small project. The end quality is pretty good, if you play it in a reduced size screen. It should play in any standard media player, including Windows Media Player.
But I believe that to get the sort of quality output you are after in that small size is going to be next to impossible if you want to play it full screen...
I don't think even the big movie studios, with their million dollar software programs can do that, clever though those programs might be. But in a low priced package like VS, it would be many bridges too far...I had hoped that it would compare my objective [by using something like "AI" (Artificial Intelligence)] to the -many- options it has built within itself, and then produce an optimal file (based upon what I had asked for). It doesn't do that.
Yup... I fall into that category. I started around 2003 with Video Studio 7 and had never edited a video before in my life. So it has been a learning curve ever since. I have flirted with a number of other packages, including Adobe Premiere CS4 and Elements, Cyberlink PowerDirector, and Magix, but have ultimately always come back to VS because to me it has become very user friendly... And believe me, you would have similar problems and often an even steeper learning curve with some of the other programs on the market.Or, else maybe some of you took the weeks/months... even years!, and lots of trial and error [like I'm forced into doing], in order to educate yourselves.
Same here. I am 63, and without checking, some of our other Site Admin people and Moderators are around the same age as you and me. But we enjoy video editing, and mastering VS has certainly not been beyond us because of age. So there is is definitely hope for you yet!!At 67, I'm not as sharp as I used to be at age 19!
