Paintshop Pro - Wishlist for version X6
ellenelle
- ram: 3.5 GB
Re: PaintShop Pro - Wishlist for Version X6
I'd like to put in my request for SVG support, import and export.
Ellen
Ellen
lillcutie
- motherboard: ASUSTeK Computer INC. P8P67 LE Rev X.0X
- processor: Intel R Core TM i7-2600 CPU 3.40GHz
- Video Card: NVIDIA GeForce GT 430
- sound_card: NVIDIA High Definition Audio 4x
- Hard_Drive_Capacity: 1863GB
- Monitor/Display Make & Model: Philips 221E Monitor
I would like to see return of
1. Image - Mirror
2. Text box - option to remember text
Thank you
1. Image - Mirror
Thank you
Joelle
- motherboard: Asus Prime B350M-A
- processor: AMD Ryzen 5 1500 Quad-Core
- ram: 16 GB RAM
- Video Card: NVidia GeForce GTX 1050
- Hard_Drive_Capacity: 1TB
- Monitor/Display Make & Model: Samsung
- Corel programs: PaintShop Pro X9
It's a great shame that Corel thinks that messing around with PSP has 'improved' things.. no it hasn'tlillcutie wrote:I would like to see return of
1. Image - Mirror
Thank you
I use Ctrl+M to mirror something, then activating M for the Move Tool and using the Arrow Tool to nudge it into place. A long way around, but do-able.
As for the Text Tool.. it's a mess and takes much longer to do the same things we used to do when the Text Box was the only option.
You can still get the Text Box back, see attached.
To Edit the Text, double-click on the Text Layer in the Layers Palette.
Joëlle
Joëlle
(PSPX9 )
(PSPX9 )
Cassel
- ram: 16Gb
- Corel programs: PSP 8 (JASC) to PSP 2023
Although the Text Entry box is still an option (an alternative to typing on the project itself), i wish there was a way to set it as a preference instead of having to hold the Shift key to get it all the time. Yes, i am lazy, but a few seconds saved in one command, multiplied by thousands of times for using it would really add up.
I also find that working on the project, although it might give a more visual result, requires to accept by moving the mouse all the way up every time, which is quite cumbersome i find.
Cassel
https://scrapbookcampus.com
Joelle
- ram: 16 GB RAM
Everything takes longer nowadays.Cassel wrote:Although the Text Entry box is still an option (an alternative to typing on the project itself), i wish there was a way to set it as a preference instead of having to hold the Shift key to get it all the time. Yes, i am lazy, but a few seconds saved in one command, multiplied by thousands of times for using it would really add up.
Corel is in need of a very powerful hearing aid ..
As for using the Text Tool for more than a few words, I use Xara's text tool, it's a dream
Corel is very busy shooting itself in the foot, actually, in both feet...
Joëlle
Joëlle
(PSPX9 )
(PSPX9 )
LindaSue
- motherboard: Gigabyte
- processor: 2.71GHz AMD Athlon II X2 215 processor
- ram: 3 GB
- sound_card: Realtek AC97 Audio [onboard]
- Hard_Drive_Capacity: 1320 GB
- Monitor/Display Make & Model: Asus MX279 HDMI 27-inch
- Corel programs: Paint Shop Pro X2, X4, X6
There is a button on the Tool Options palette for "Remember Text":lillcutie wrote:I would like to see return of
1. Image - Mirror
Thank you
Using Paint Shop Pro versions 5, 6, 7, 8, 9, 12, 14, 16
Joelle
- ram: 16 GB RAM
That's interesting, it looks quite different in my verion of X5, smaller and harder to find too :
Joëlle
Joëlle
Joëlle
(PSPX9 )
(PSPX9 )
LindaSue
- ram: 3 GB
My screenshot is X4. I assumed it was the same in X5 because very little changed between X4 and X5. Apparently Corel decided that the X4 icon wasn't very descriptive.
Joelle
- ram: 16 GB RAM
Ah, that explains it.
No doubt it will look different again in version X6
Joëlle
Joëlle
Joëlle
(PSPX9 )
(PSPX9 )
Kathy_9
- Hard_Drive_Capacity: 2TB
Maybe even before X6 as icons have a tendency to change at will and then change back again. Sorry, couldn't help myself.
Joelle
- ram: 16 GB RAM
Hehe, yup, Corel and their icons, move in mysterious ways!
Joëlle
Joëlle
Joëlle
(PSPX9 )
(PSPX9 )
- hartpaul
- ram: 8 Gb
Just tested and in X3 X4 and X5 double left clicking outside the text regeion is the same as accepting so you do not have to move your cursor up to the Tick (accept) . Only found this out today after reading your complaint.Cassel : requires to accept by moving the mouse all the way up every time, which is quite cumbersome i find.
LindaSue
- ram: 3 GB
But, there's still the issue of not being able to edit text that goes outside the margins of your image. At least with the text box, you can see all of your text and can highlight any part of it.hartpaul wrote:Just tested and in X3 X4 and X5 double left clicking outside the text regeion is the same as accepting so you do not have to move your cursor up to the Tick (accept) . Only found this out today after reading your complaint.Cassel : requires to accept by moving the mouse all the way up every time, which is quite cumbersome i find.
- hartpaul
- ram: 8 Gb
When using text a lot I have gotten into the habit of making the text small enough to fit inside the work area and then you can edit , change size , move to another line etc. But yes the text box does make that easier.
Best would probably be a text box that can be set to permanently come on or stay off and auto positions near the bottom of the screen. Then all would be happy?
Alejandro
- processor: Intel Core i5-2400 CPU 3.10 GHz
- ram: 4GB
- sound_card: NVIDIA and Realteck High Definition Audio
- Hard_Drive_Capacity: 2.000 GB
- Monitor/Display Make & Model: Samsung SyncMaster P2370MS
- Corel programs: PaintShop - Aftershot - others
I use PaintShop Pro to edit photos (tiff and jpg files, as I use a different and more specialized program to develop my raw files).
I would like the program to have the ability to convert a layer into an intelligent filter (I mean for other filters different from the Adjustment Layers which are already intelligent and or for plugins, allowing to reopen them more than once to allow further fiddling with them).
I would like, as an option that you could switch on or off, that the clone tool could show (within the circle of the cloning brush) a glance of the portion of image you are going to clone, as a transparency.
I would like that other resampling algorithms (for example Lanczose3) would be added in the advanced options for when changing the size of an image.
I would like more flexibility in the ways one could manipulate nodes in the Warp Mesh tool.
I would like that some of the corrections of variables one applies when using certain editing tools (for example the Unsharp Mask), would work more in real time (or at least a bit faster).
