Running in background even when it is closed
LHamel
processor: AMD Athleon II X3 425
Video Card: Radeon R7 200
Hard_Drive_Capacity: 500 GIG
Monitor/Display Make & Model: LG E2350
Corel programs: PSP-x9, Painter , VS-x8
Post by LHamel »
Hi everybody,
I recently bought PaintShop Pro Ultimate X5. So, the software is remain running in the background even when I quit the app. I must do CTRL-ALT-DEL and stop the process. Is it a bug ? I think is it not normal :?
Re: Running in background even when it is closed
I have often found that various Corel programs, including PSP and Video Studio, seem to keep running for some time in Task Manager > Processes after I have closed the program. This usually stops me from re-opening the program a few minutes after I closed it. I then have to go to Task Manager > Processes and highlight the program entry then press the 'End Process' button.
In other words, I get the same problem as you and don't know the answer why. I have learned to live with it over the years as I appear to be only one of a very few users who have -- or at least notice -- the problem. In my case, I find that after about 10 minutes running in the background, the program does in fact turn itself off. But the really curious thing is that sometimes it also turns off immediately I close it. Go figure! :cry: :roll:
Tadjio
processor: Core i7 2.8GHz 860
Video Card: ATI HD5570
sound_card: Sound
Hard_Drive_Capacity: 2.5TB
Post by Tadjio »
Under File / Preferences / General Program Preferences / Manage there is an option:
"Allow cataloging to complete after exiting the application"
Set this off.
Tadjio
PSP X7.2 Ultimate user
AfterShot Pro 2.1 ASPirant
Windows 8.1 64-bit Pro
Canon EOS 100D, Olympus E-PM1 & iPhone 6
kaymann
motherboard: ASUS P8P67 PRO REV 3.1
processor: Intel i-7 6800K
ram: 32 GB
Video Card: NVidia GeForce RTX 2060
sound_card: Onboard
Hard_Drive_Capacity: 3.5 T
Monitor/Display Make & Model: MSI MAG 341CQ & Dell 2470
Corel programs: PSP 2019 Ult, Painter 2020, CorelDraw X7
Post by kaymann »
Tadjio beat me to the punch. However, the other side to is to know what is happening and let it go. Your system is high end enough to just let it finish up as the degregation in system resources is probably minimal.
alanpalmer
motherboard: Dell Inc. 0WXY9J A12
processor: Intel dual Core i3 CPU M380 2.53GHz 2.53 GHz
ram: 4GB
Video Card: Intel HD Graphics
sound_card: Intel Display Audio
Hard_Drive_Capacity: 564 GB
Monitor/Display Make & Model: PHILIPS 200P4
Post by alanpalmer »
Yes, while PSP is building the catalog for the first time it is likely to stay in memory for some time after closure. However, once it finally completes it should quit much earlier. As kaymann indicates, let it run unless it's really affecting other work.
TOP TIP: Paint your lawn blue. If someone uses Google Earth to check out your home, they'll think you own a swimming pool.
LHamel
Post by LHamel »
Thank you very much. Your comments are very appreciated.
LHamel
Post by LHamel »
Good morning,
I let go of the process (paint shop pro) overnight. This morning it is still there. I click the icon to launch the application, it will not start. I absolutely stopped the process. In addition, I have done what Tadjo wrote : Set this of "Allow cataloging to...". But, it does not work. :(
Have a good day.
LHamel
Post by LHamel »
Bonjour,
Is this normal, when I work with "Paintshop pro X5", the application takes a lot of resources and the fans run at maximum speed ? Besides, he continued to work (in background) after leaving. Also, is it normal that the application is installed in the folder "Programs files (x86)" ? Thank you very much.
kaymann
ram: 32 GB
sound_card: Onboard
Post by kaymann »
LHamel wrote:Bonjour,
I have a simular system as yours and I do not experience the resource hogging you describe.
I do not have any left over processess now that my catalog is caught up (first run only).
Most programs are true x86 (32bit) with code to dummy down the 64bit OS to allow the 32bit instruction set.
32bit v 64bit is simply the length of the instructions sent to the cpu. The longer the set, the more instructions you can create and the more memory you can put an address to. In other words the more precise your instructions can be. The more precise your instructions the quicker you get things done. PSPX5 is native 32bit so it lands in the 32bit "Program Files (x86)" folder. True 64 (as opposed to 64bit capable) programs land in the "Program Files" folder.
In your case I would kill your catalog and start again.
LHamel
Post by LHamel »
Thank you Kaymann,
Just a question : How long does it take for your catalog is caught up ?
alanpalmer
ram: 4GB
That depends on how many images you have on your computer.
LHamel
Post by LHamel »
alanpalmer wrote:That depends on how many images you have on your computer.
I understand very well. But, this is not normal after 24 hours. I had to stop the process to launch the application because it would not start.
kaymann
ram: 32 GB
sound_card: Onboard
Post by kaymann »
I have roughly 50,000 all in all and I do not ever remember going over a coulple of hours. I would usually start the catalog build and walk away. When I got back it would be done. Sorry I can not be more acccurate than that. However never 24 hours! I am begining to think your catalog is barfing on a specific photo. Wondering if there is a way you can narrow that down by last folder imported or something simular....
LHamel
Post by LHamel »
As strange as it may seem, the problem is solved. I don't know why but is solved. :?
Pantera3k
processor: Intel Core i7
Post by Pantera3k »
Now is 2023. And I frequently find VS 2023 sits and eats CPU resources in the background even I closed it. Basically did it yesterday. But still found this in the morning. Memory leakage? Concurrency mining? Any thoughts?
