Removing Audio Track
I am trying to remove the original audio track and replace it with a new one. Is the only way to do this by muting the original audio track, or can you delete it completely? Thanks.
Re: Removing Audio Track
yes you can only mute the sound within VideoStudio.
You could right click on the video clip and choose 'split audio' - the audio will then appear in the audio track where you can delete it - BUT - that has only muted the sound in the video because you can still right click on the video track and un-check the 'mute' option.
so muting is your only option - it has the same effect in your final video.
