PSPx5 Bugs and Fixes.
SJS
motherboard: Dell Inc 0KWVT8 A03
processor: 11th Gen Intel Core TM i7-11700
ram: 16 GB
Video Card: NVIDIA GeForce GTX 1660 Ti 6GB GDDR6
sound_card: Onboard Realtek Codec
Hard_Drive_Capacity: 4 TB
Monitor/Display Make & Model: DELL U2412M
Corel programs: PaintshopPro 2022 Ultimate
Re: PSPx5 Bugs and Fixes.
Post by SJS »
Oops, wrong version... never mind!
wacigarbear
motherboard: Gigabyte Technology Co Ltd GA970AD3
processor: 2.80 gigahertz AMD Phenom II X3 720
ram: 16378 Meg
Video Card: AMD Radeon HD 7700 Series
sound_card: on motherboard
Hard_Drive_Capacity: 1 tetrabit
Monitor/Display Make & Model: 47" vizio HD TV
Post by wacigarbear »
I've been reading this board and I've found I'm having the same problem some others are having. I installed the problem back in Nov 2012 when I got it. I dropped PS, it was too confusing. So I went to start up PSPx5 and it won't stay open. I've reinstalled it like someone suggested but nothing. The screen populates but the pointer is an hourglass, then the message - windows needs to shut down the problem. I bought the program but I can't get it to run. PSPx4 works fine. Do I need to remove PSPx4 to run PSPx5? I'm lost and I've got holiday cards to make.
Thanks!
josephlin
Alludo
motherboard: Intel Z490 chipset
processor: Intel Core i9-10900K
ram: 32GB
Video Card: nVidia RTX 2070S
sound_card: Realtek ALC892
Hard_Drive_Capacity: SSD 1TB
Post by josephlin »
wacigarbear wrote:I've been reading this board and I've found I'm having the same problem some others are having. I installed the problem back in Nov 2012 when I got it. I dropped PS, it was too confusing. So I went to start up PSPx5 and it won't stay open. I've reinstalled it like someone suggested but nothing. The screen populates but the pointer is an hourglass, then the message - windows needs to shut down the problem. I bought the program but I can't get it to run. PSPx4 works fine. Do I need to remove PSPx4 to run PSPx5? I'm lost and I've got holiday cards to make.
Thanks!
Hi Sir:
This is Joseph who PM of PaintShop Pro. I'm sorry for seeing the problem you met and would like to assist you to resolve the problem as far as possible.
1. Please download our cleanup tool (https://dl.dropbox.com/u/6132040/PSPX5_Cleanup_v1.0.zip) to remove PSPX5 program completely from your system at all.
2. Install PSPX5 and launch it. Please let me know if the crash issue is still there. (Follow up with step below if the issue was existed)
3. Download SP1 (http://www.corel.com/akdlm/6763/downloa ... X5_SP1.exe) and install it.
4. Please refer to attached doc to download hotfix and follow the step to apply it into program.
5. Launch PSPX5 again.
PSPX5 Hotfix_20121210.docx
(39.33 KiB) Downloaded 509 times
Cheers
Joseph Lin
Sr. Program Manager,
Corel PaintShop Pro / AfterShot Pro / VideoStudio
wacigarbear
ram: 16378 Meg
Thank you so much! It worked!
Happy Holidays
Robb
arik1942
Post by arik1942 »
Thanks!
Hi Sir:
I'm having a similar issue that I can't seem to resolve. I used the clean up tool to uninstall PSPx5, then restarted my computer and reinstalled the program. That was as far as I could get. It installed but immediately upon opening, it crashes. There is no time to even so much as click on anything it happens so fast. Should I proceed with SP1 anyway and give that a try? I can still use PSPx4 but I am anxious to try the new version. This is my 3rd attempt at uninstalling and reinstalling but so far no luck. I appreciate any help anyone can give me. I'm on Window 7 Ultimate and to date had no issues with installing any program successfully - unfortunately, my track record has come to a standstill. Thanks for your help!
Nells250
Corel programs: PSP9, PSPx9
Post by Nells250 »
OldRadioGuy wrote:
LindaSue wrote:
And this is what I get in X5 (greyed out):
LindaSue, here's the way it looks on my system (X5):
Bob
I wish I could get that to work!
Rascal101
Post by Rascal101 »
LindaSue wrote:And now for the bugs:
4. The vector text bug hasn't been fixed and it's been around since at least X3, I think. An extra space is added at the end of every line of text which makes it impossible to center align the text inside the bounding box. I can't believe that Corel hasn't fixed this considering how many people have complained about it.
Linda if you add the text to your layer it will prevent the extra space..(right click on Vector 1 inside layer box and Promote to layer) Hope it helps
Rascal101
LindaSue
processor: 2.71GHz AMD Athlon II X2 215 processor
ram: 3 GB
Video Card: ATI Radeon HD 4350
sound_card: Realtek AC97 Audio [onboard]
Hard_Drive_Capacity: 1320 GB
Monitor/Display Make & Model: Asus MX279 HDMI 27-inch
Corel programs: Paint Shop Pro X2, X4, X6
Post by LindaSue »
Rascal101 wrote:LindaSue wrote:And now for the bugs:
Rascal101
That's not really a solution. One of the benefits of vector text is that you can go back and edit it later. If I have to convert it to raster then I can no longer do that.
Using Paint Shop Pro versions 5, 6, 7, 8, 9, 12, 14, 16
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Post by LeviFiction »
That is why I made scripts to handle the aligning. They allow me to align the text but keep the original text vector. However, I didn't make it intelligent (I was lazy) so it's still a pain. The odd thing is that this bug doesn't happen for everyone. A very few people don't ever see that extra space at the end. According to Simone the developers claimed they would try really hard to fix it in SP2 of X5. However, as we know "try" means they haven't solved it yet and so is no guarantee.
FredL
motherboard: Dell Inc. 04373Y A03
processor: Intel Core i5 M 560
ram: 4GB
Video Card: Intel HD Graphics
sound_card: IDT High Definition Audio CODEC
Hard_Drive_Capacity: 250GB
Monitor/Display Make & Model: CMO 14
PSPx5 Bugs and Fixes: Nik Silver Efex Pro
Post by FredL »
I've been trying to use the latest Nik Software plugins:
Color Efex 4 is not supported
Silver Efex Pro 2 is not supported
Unfortunately, because I am an enthousiast B&W photographer I absolutely want to use these plugins.
I've been using PSP since 1990 (v3.14!) and I am currently using the X4 Ultimate
It seems I have no choice but to divorce from Corel and move to Adobe Photoshop :oops:
Walpole1
ram: 4gb
Hard_Drive_Capacity: 1tb
Monitor/Display Make & Model: hp
Post by Walpole1 »
Nells250 wrote:
Bob
If you are using the Organiser with the Collections tab selected in the Navigation window, then you can change the sort order of the images in the Organiser to whatever you want.
If you are using the Organiser with the Computer tab selected in the Navigation window, then the sort order option is greyed out. Not sure why, a bug, or ??
If you are using the Computer tab, then just change to the Collection tab, change the sort order, and then change back to the Computer tab.
Walpole1
Szczur
operating_system: Vista Home Basic
motherboard: FUJITSU SIEMENS EF7 D3A
processor: Intel Pentium Dual-Core
ram: 4GB
Video Card: Mobile Intel 4 Series Express Chipset Family
Hard_Drive_Capacity: 320.07 GB
Monitor/Display Make & Model: Generic PnP Monitor (15,3"vis)
Post by Szczur »
AdrianW wrote:I contacted support about X5 becoming unresponsive in Windows 8 (see previous post), and they confirmed it was a known issue and that they were working on it.
They gave me access to a hotfix patch, but it failed to fix the issue for me. (The hotfix bumped the version number up to 15.1.0.11).
I'd love to know what's happening with this. I just bought X5 (my first upgrade since version 9) and it becomes unresponsive as soon as I touch "edit". Sadly, this became apparent after I'd already chosen to make edit my default startup screen. So... I have a new, licensed, completely unusable program.
Does anyone have any thoughts on how to at least alter the default start up environment without actually running the program?
josephlin
Alludo
ram: 32GB
Re: PSPx5 Bugs and Fixes: Nik Silver Efex Pro
Post by josephlin »
FredL wrote:I've been trying to use the latest Nik Software plugins:
Hi Sir, sorry for making this negative impression to you. Actually both of them cannot work well with PSP is known issue and the root cause is due to Nik software part. Corel side is asking Nik software to resolve this crash issue soon and the issue might be resolved in further update.
Cheers
Joseph Lin
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Post by hartpaul »
Using the Gif Optimiser:
1. place an image on the workspace.
2. Do Save As and select GIF.
3. Choose Gif optimiser and Colors Tab.
4. When changing the number of colors up in the GIF Optimiser the size updates as well as the image but when you reduce the number of colours it does not update the size. This happens for me in X4 and X5. It does work correctly in X3 and does go up and down to show the save size as you choose a different number of colors. So for me they broke it between X3 and X4.
Babble
motherboard: ASUS M4A78T-E
processor: AMD Phenom II X4 945 3GHz
ram: 8 GB
Video Card: XFX Radeon HD6750
sound_card: Via HD sound
Hard_Drive_Capacity: 1 TB
Monitor/Display Make & Model: Asus PA238Q
Post by Babble »
Corel has yet again become the most annoying software company in the photo business. They release product with stupid bugs and lots of them. Absolutely no quality control and now no way to contact them about the problems. Post something here and maybe someone will give you a hint or maybe not. I use X4 and my trial version of X5 will not read my Sony RAW files. How stupid is that? The Corel web site is just a big circle jerk unless you want to pay to tell them the product is crap. Yeh, I'm fed up and you should be too. I'm going to download elements and try that.
