PSPx5 Bugs and Fixes.
Walpole1
ram: 4gb
Hard_Drive_Capacity: 1tb
Monitor/Display Make & Model: hp
Re: PSPx5 Bugs and Fixes.
Post by Walpole1 »
LeviFiction wrote:The option to "Sorty By:" disappears for me if I have the "Computer" tab selected in the navigation pane. If the "collections" tab is selected I'm able to sort normally.
Tried this and it seems to be the case for me as well. The Sort By options come back if I am on the Collections tab, but disappear if on the Computer tab. Bit of a workaround but I guess it will do for now.
Thanks.
Walpole1
LindaSue
motherboard: Gigabyte
processor: 2.71GHz AMD Athlon II X2 215 processor
ram: 3 GB
Video Card: ATI Radeon HD 4350
sound_card: Realtek AC97 Audio [onboard]
Hard_Drive_Capacity: 1320 GB
Monitor/Display Make & Model: Asus MX279 HDMI 27-inch
Corel programs: Paint Shop Pro X2, X4, X6
Post by LindaSue »
That works for me too but I don't have to switch tabs in X4 to get the sorting menu.
Using Paint Shop Pro versions 5, 6, 7, 8, 9, 12, 14, 16
jaxman43
motherboard: PEGATRON CORPORATION 2AC2 2.00
processor: 3.40 gigahertz Intel Core i7-2600
ram: 8 GB
Video Card: NVIDIA GeForce GT 520
Hard_Drive_Capacity: 3 TB
Monitor/Display Make & Model: HP 2311
Post by jaxman43 »
Same here. I didn't realize that until you pointed it out.
stobert
Post by stobert »
burt_ie wrote:X5 had become pretty useless at the moment, I still have X4 installed and having to use that in the meantime.
I bought X5 Ultimate for the extra features but I cant even use them. Hope Corel can get this fixed soon :(
Same here: freezes, crashes, only Task Manager works to close after a freeze or crash. Really disappointing...
brucet
operating_system: Windows 8.1
Post by brucet »
Are these issues a Corel 'issue' or is it rather an operating environment issue?
I wish these sorts of discussions were first in another thread rather than on this thread which is for 'confirmed' issues.
Regards
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Post by hartpaul »
brucet wrote:Are these issues a Corel 'issue' or is it rather an operating environment issue?
Regards
I also suspect that that is the case. I have just installed X5 and now have installed PSP8, X2, X3, X4 and X5 and all sem to be happy. Glad the Tabbed documents problem (common problem ) has been solved. The extra space after Vector Text (again a common problem) appears on my system as well. Have not so far had X4 or X5 freeze or crash .
Am wondering if the people experiencing these problems (and blaming Corel) may be having program conflicts. Would be interesting to (as you have suggested) compare what systems are experiencing these problems and also what other programs are being used that may be causing conflicts.
eg what AV and firewall are people using that are having these freezes. (could for example Norton AV be a commonality).
I have used a program called Belarc Advisor to maintain a record of the programs I have installed and also to alert me if there are any hotfixes that are required.
http://www.belarc.com/free_download.html
THis could be very useful if a program was working correctly and then later it stops working. If you have done a snapshot before and compare with the snapshot after you can see what changes you have made that may be a cause of conflict.
stobert
Post by stobert »
I solved my PSP X5 won't open files/freezing/won't shut down problem this morning. It worked under another profile on the computer, but not mine. I blew away my profile, created a new one, and verified PSP5 worked normally (it did). From backup, I restored one profile element at at time, checking PSP X5 after each step. Lo and behold , when I restored My Videos, the problems appeared. When I deleted the videos, I couldn't delete some because "file is in use by Corel Paintshop Pro". I moved My Videos to a different drive, works great now. I can't say this will work for anyone else, but it solved my problems. 8)
burt_ie
Post by burt_ie »
In regards to my freezing problem: I am running a fresh install of Windows 8 Enterprise RTM evaluation 64bit, no anti virus or firewall installed, just the built in Windows firewall and Microsoft security essentials. Have tried PSPx2 and PSPx4 and they both work fine with no problems but x5 seems to freeze within seconds of it opening. Have unistalled and reinstalled but its still the same.
As for stobert's fix...I don't really want to go moving my video folder around, there's thousands of GB's in there!
fs999
System_Drive: Z
motherboard: Intel
processor: i7 860
ram: 32GB
Video Card: NVIDIA GeForce GTX 730
sound_card: Samsung HDMI
Hard_Drive_Capacity: 28 TB
Monitor/Display Make & Model: Philips 24P4 & Samsung UE46M6050
Corel programs: PaintShop 2023 Ultimate
Post by fs999 »
Visible Watermark is still 8bit.
You can still not use the DEL key in an editbox in a toolbar, it deletes the selection.
randymacon
motherboard: Intel Corporation DX48BT2 AAE26191-206
processor: 2.85 gigahertz Intel Core2 Quad Q9550
ram: 4 Gb
Video Card: NVIDIA GeForce 9800
Hard_Drive_Capacity: 5 TB
Monitor/Display Make & Model: ViewSonic VA2231
Post by randymacon »
I have a similar problem. Whenever I try to merge a layer with less than 100% opacity, X5 stops working. I can use X4 to merge the two, but I have already spent my money on X5. At this point I regret the expenditure.
ADonahoo
motherboard: Dell Inc. 0KWVT8 A03
processor: 3.60 gigahertz Intel Core i7-4790
ram: 24GB
Video Card: AMD Radeon R9 270
sound_card: Creative SB X-Fi Titanium
Hard_Drive_Capacity: 13256GB
Monitor/Display Make & Model: Dell SX2210 and Dell ST2210
Corel programs: PSP X7, X8, X9, 2018, 2019
Post by ADonahoo »
X5 Save Copy As command add a second .pspimage extension to the file name. Confirmed by two other people in this thread http://forum.corel.com/EN/viewtopic.php?f=56&t=47970.
ralphyboy
Post by ralphyboy »
take a look at the task manager... when X5 freezes it stays at 25% of CPU - never moves, I start up X4 and it stays at 0% until i use... there is an issue with the X5 version ... it just freezes like version 2 did until it was resolved..
greg30127
processor: i7 1st gen
ram: 12gig
Video Card: 512meg
Post by greg30127 »
Crashes after series of adjustments:
My X5 Ultimate is crashing every single time after I do adjustments and get to a save stage.
My typical path when this happens:
Open image - resize for web viewing.
Adjust shadow/highlights
Adjust color
Adjust levels
Add a watermark with text tool
Go to Export- JPG optimizer, and it's here where EVERY time, it stalls for a second then I get the message that the program has encountered an error and must close. It then closes without saving my pic.
Even if I save my photo midway and get to this last stage, it crashes. If I JUST go to JPG optimizer from an image it won't happen, it seems to happen after doing a small list of adjustments, every time. X4 and X3 Ultimate did not have this problem (same computer), nor do any other programs I run on it. I have cleared temp files and things from the system but to no avail.
Unfortunately I bought this at a store because it was on sale, and the store won't accept the return because obviously it's opened software. Corel won't accept it because I didn't buy it directly from them. I'm out $50.00, it seems, with worthless software. I'm somewhat tired of each version having so many bugs that we have to wait for fixes with each incarnation, but not even being able to save an image is of course unacceptable. Anyone else having this exact same issue?
dinasset
motherboard: asus p7p55d
processor: intel core i5 750
ram: 4096 mb
Video Card: ati radeon hd 4800
sound_card: radeon 4850
Hard_Drive_Capacity: 2 tb
Monitor/Display Make & Model: asus vw246
Post by dinasset »
randymacon wrote:I have a similar problem. Whenever I try to merge a layer with less than 100% opacity, X5 stops working. I can use X4 to merge the two, but I have already spent my money on X5. At this point I regret the expenditure.
This happens also to me.
For the moderator:
you can test this bug by doing the following:
1-open an image
2-duplicate the layer
3-set for instance "multiply" as operation between the two layers
4-use layers fn FLATTEN function without changing the opacity: RESULT=OK
4b-set opacity to something less than 100%
5-use layers fn FLATTEN: RESULT=CRASH
Hope the pòroblem will be solved soon, thanks
Radim
ram: 4GB
Monitor/Display Make & Model: 27 inch
Post by Radim »
For the moderator:
1-open an image
Works fine on Windows XP sp3. No crash.
