I made 2 slideshows using the same photos. 1 in MSP and the other in MovieFactory.
When I played the slideshows the MSP product had line twitter but the MF version did not.
Anyone know why ?
Why line twitter in MSP slideshow but not MovieFactory
heinz-oz
Jerry Jones
In MediaStudio Pro, you should right-click on the source images and then select the "Media Source Options" and then select "FRAME-BASED" in the drop-down menu and then CHECK the "Flicker Reduction" option.
The "Flicker Reduction" option is appropriate if you are editing MiniDV clips, for example, and your project settings are "Field A."
The "Flicker Reduction" command simulates fields from a FRAME-BASED source such as a digital still camera image file.
Jerry Jones
http://www.jonesgroup.net
Jerry Jones
Gateway 7426gx
http://tinyurl.com/hagye
