How to make a ISO instead of burn disc?
chubom
Post by chubom »
Dear Sir:
My Videostudio is in Chinese(I hate it but no choice in HK shops), so sometime is hard for me to understand how to do this and that!
I see some topic said I can try to make a ISO first instead of using the burn function, I try to output the project to a videso and a m2t file come out, I getting confuse now, how can I make the ISO file, by using the create video file? or create a disc?
I have different project all put in one disc, if I burn the ISO, still have the menu?
Thanks for your help!
Best regards,
Chubom
Re: How to make a ISO instead of burn disc?
If you are making a DVD, you do all your editing and then go Share > Create Disc > DVD. You build your menu. Then on the last page of the burning process, you have the choice to burn a disc and/or create an ISO file (and/or create a DVD folder).
If you are wanting to make Blu-Ray disc, however, there is no option to make an ISO -- the only possibility is to make a Blu-Ray folder (which is the BDMV folder found on Blu-Ray video discs).
chubom
Post by chubom »
Can the bluray file use to burn a Bluray Disc?
Yes - you can use a program like Nero or the freeware ImgBurn to burn the Blu-Ray Folder to a Blu-Ray disc.
chubom
Post by chubom »
Dear Sir:
How can I test the folder if my movie is OK?
Just copy the whole thing into a bluray disc? it will run automatically?
Best regards,
David
Post by BrianCee »
If you have a software player on your computer - like WinDVD - which can play blu-ray disc you can use that - just point the player to the folders you have made.
chubom
Post by chubom »
When burn the bluray, do I select to burn as a movie or just burn the data into the bluray disc? is it just select all the file in the output folder and burn into the root of the bluray disc?
Best regards,
Chubom
Post by BrianCee »
if you have created blu-ray folder you burn the new folder itself (complete with everything inside the folder) to the disk - not individual files.
the blu-ray burner programme should know what to do.
chubom
Post by chubom »
Thanks, will try but still long way to go, haha!
