PSP x5 freezes on opening
Hi!
Just tested psp x5 on my Windows 7 home premium 64 bit system.
After installing it loads just fine but freezes immediately when trying
to open a picture via menu ore open-button.
Somebody noticed the same or found a solution?
Thanx
valhalla
Thanx
valhalla
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
Re: PSP x5 freezes on opening
No, it doesn't even get that far.
It doesn't even open a fileselection window.
Also the program freezes immediately when dropping a picture to the workspace,
no matter where it is locatet or what filetype it is.
javafool46
- motherboard: PEGATRON CORPORATION TRUCKEE 1.04
- processor: i7 CPU
- ram: 12gb
- Video Card: ATI Radeon HD 4850
- Hard_Drive_Capacity: 1.0 TB x 2
- Monitor/Display Make & Model: DELL U2410 & ELL 2408WFP
I am having the same freeze problem. Mine actually opens a JPEG photo then freezes. Any word on this yet?
MarkZ
- motherboard: Intel DQ67SW desktop
- processor: Intel Core i7 i7-2600 3.40 GHz
- ram: 8 GB
- Hard_Drive_Capacity: 500 GB
- Monitor/Display Make & Model: LG Flatron E2241
- Corel programs: PSP 2018 X9 X8 X7 X6 ASP3 ASP
In my case the program freezes whenever I first access any file in Organizer - Task Manager states "program not responding". After about a minute it starts working and is fine after that. It may be that the first time you try the program the delay may be far longer than in my case and after it sorts itself out the delay is brief.
Mark
ADonahoo
- motherboard: Dell Inc. 0KWVT8 A03
- processor: 3.60 gigahertz Intel Core i7-4790
- ram: 24GB
- sound_card: Creative SB X-Fi Titanium
- Hard_Drive_Capacity: 13256GB
- Monitor/Display Make & Model: Dell SX2210 and Dell ST2210
- Corel programs: PSP X7, X8, X9, 2018, 2019
I can't get the Organizer to show me any images at all, and I really wanted to use it. And these are pngs and jpegs but they are on an external drive. Could that be the problem? I see images in My Pictures and one other folder on the C drive.
- ram: 6 GB
Have you tried deleting the image database? I've seen that fix the "no image" problem before.
ADonahoo
- ram: 24GB
I loaded a blank database when I installed the program. And where do you delete the database from?LeviFiction wrote:Have you tried deleting the image database? I've seen that fix the "no image" problem before.
- ram: 6 GB
It's in a hidden folder called AppData.
C:\users\username\AppData\Local\Corel PaintShopPro\ 15.0\ Databases\Imagedb.db
ADonahoo
- ram: 24GB
LeviFiction wrote:It's in a hidden folder called AppData.
Thanks a lot. I've seen that folder; mine are not hidden.
javafool46
- processor: i7 CPU
- ram: 12gb
I just went in to delete the ImageDb and couldn't find it anywhere. I tried opening PSP X5 and after waiting there was a prompt "restore Image data base?". I clicked yes and the program is now resopnding.
Go figure
I don't know why it worked but for now I am ready to try out PSP X5.
Go figure
ADonahoo
- ram: 24GB
Well, that worked. Don't know why but thanks so much for letting me know. I'm liking X5 so far.ADonahoo wrote:LeviFiction wrote:It's in a hidden folder called AppData.
I deleted the database file and replaced it with a empty textfile with same name
that I made read-only before.
Now it works like a charm.... Strange anyway
patara
- motherboard: ASUS Prime Z690 DDR5
- processor: Intel i7-12700K CPU 12 Core
- ram: 32 GB
- Video Card: GeForce GTX 1060 GI Gaming 6G
- sound_card: VIA High Definition Audio
- Hard_Drive_Capacity: 1TB SSD +22TB Hard Drives
- Monitor/Display Make & Model: Dell U2715H
- Corel programs: PSP7 to PSP 2023
I keep a shortcut to AppData and ProgramData on my Desktop. Using them I have no need to unhide the folders as it takes me driectly to that section and I can see all files.
I am getting freezing when closing JPEG files. I have tried deleting the database file and rebuilding the database, it works for a short while and then freezes again
I hope there is a fix to this soon because PSP X5 is great when it doesn't freeze.
