No, I have not calibrated lenses in ASP.ferdinand-paris wrote:The type and number of images are exactly the same as for the B5/ASP procedure. If you've calibrated lenses in ASP then the procedure is the same, but the tool is different.
F_P
Yes, I did read the link but, as I understand what you are saying, it is not necessary to do any s/w calculations since all I need to do is use the straightening tool and then "train" PN at the various focal lengths. That certainly seems a lot easier to me.ferdinand-paris wrote: Did you read that link? So for a 18-55 I took shots at 18, 21 24, 28, 35, 45, 55. In ASP you have to use some external s/w to calculate the (a,b,c) parameters for each focal length and insert the results in the lens DB (a text file). ASP interpolates for intermediate focal lengths. PN is similar. You use the line straightening tool on each of these images and then "train" and PN will also interpolate for intermediate focal lengths. That's my understanding and experience. What's the problem? The only hard part is to select the right kind of wall / building to use as your target. Do not use brick walls.
F_P
I re-read the link with what you have said in mind and it now seems like a very easy process. Find straight lines to photograph, start taking images from about 3 meters or so away, take then every 10% (for the edges) and 15% (for the rest) of the various focal lengths, straighten the images and then "train" them. For a 17-35mm lens that would seem to be 17, 19, 21, 24, 27, 30, 32 and 35 and that is probably more than I need to do. I assume the more straight lines in the image the better and that I should be straightening all of them.
It is too dark to do a good job now but I will try this tomorrow. I hope that this process helps take care of the distortion in my lens when processed by PhotoNinja and I wonder if it will have any effect on the vignetting I see with my UWA when it is wide open. I assume the distortion correction will push some of the image out of the frame and that may have an effect. Also, when I sent one of these images to PictureCode to ask them why the vignetting adjustments in PN do not correct the vignetting in the image, one of the developers responded that perhaps PN, since it shows more of the image than specified by Canon, is displaying too much at the edges. It will be interesting to see if the lens distortion adjustments take care of the vignetting.
Thanks for the response.
