I have rendering problems with Mercalli plugin - rendered video contains in the stabilized clips Mercalli error report " Must analyse again". All source clips (FullHD, 25fps) are correctly analyzed and stabilized - confirmed by clip playback in videostudio. Project properties are set to DVD resolution in 25fps. Last night I've discovered that if I set Output format to MPEG-4 FullHD 30fps rendered video is correct. Other output formats e.g. DVD 25fps, HDTV 25fps result to "Must analyse again" warning. It seems to me that VideoStudio X5 has serious problems with 25fps video processing as it is not even possible to create 25fps FullHD MPEG-4 video (simply codec configuration doesn't supports 25fps for FullHD).
Does anybody in Europe experiences such problems?
X5 and proDAD Mercalli rendering problem
Re: X5 and proDAD Mercalli rendering problem
Regarding Mercalli, have a look at this post which may answer your question: http://forum.corel.com/EN/viewtopic.php ... 25#p251225
habanr
- processor: Intel i7-3610QM
- Video Card: NVIDIA GeForce GT 630M
- Hard_Drive_Capacity: 1TB
Thank you very much, the option "Frame-based" is the solutionKen Berry wrote:Regarding Mercalli, have a look at this post which may answer your question: http://forum.corel.com/EN/viewtopic.php ... 25#p251225
