Thanks Trevor!
That's a very elegant solution to get the effect; particularly with the fade-in of the overlay so it's not necessary initially to position it precisely.
I guess part of the "take home" from this whole discussion is that some things can't be done!
David
Pan & Zoom and image resolution
david1939
- motherboard: Unknown
- Hard_Drive_Capacity: 465GB
- Corel programs: VS ultimate 2023,MotionStudio 3D
Re: Pan & Zoom and image resolution
SONY DCR-HC42 Handycam, VideoStudio X4 Pro, X5 Pro, X6 Pro, Motion Studio 3D
Hi David
You could simply add both images to the top track and use X-fade to transform from one to the other.
P-in -P was just one solution.
I have taken it a little further by creating 9 images as a montage of the full image. Unfortunatley you can see the joins.
10 overlay tracks one for each image, + one spare overlay track apply P-in P to each.
Dont think it would ever get used as i think there must be easier options, but was interesting in setting it up.
A little bit more to do and i will make that available if you are interested.
P-in P gets easier the more you work with it?
david1939
I think the movement in the P-in-P is much better than doing a simple x-fade!You could simply add both images to the top track and use X-fade to transform from one to the other.
Yes, I am interested -- I've not worked at all with P-in-P at all so far.A little bit more to do and i will make that available if you are interested.
Best,
David
