Ubuntu 10.04 Nikon D300
lidiving
operating_system: Linux
Post by lidiving »
Unable to import images when I plug in my d300. Ubuntu 10.04 sees the camera but aftershot dosent. Am I doing something wrong?
Trucks
System_Drive: N/A
motherboard: 64bit
processor: quad
ram: 3GB
Video Card: Nvidia
sound_card: onboard
Hard_Drive_Capacity: 2TB
Monitor/Display Make & Model: Eizo S2243 W
Re: Ubuntu 10.04 Nikon D300
Post by Trucks »
can you change the Protocol in the Cam PTP or something. It should work with a normal Card Reader.
Regards
Trucks
lidiving
Post by lidiving »
Ubuntu sees the CF card fine. Aftershot cant seem to find the card. Shouldn't it just find it and ask you if you want to download it like Lightrrom.
afx
System_Drive: N/A
Video Card: FirePro 4900
Post by afx »
What is the mount point?
cheers
afx
lidiving
Post by lidiving »
USB.
When I plug my D300 in. Ubuntu asks me what I want to open it with. I choose Aftershot......and aftershot opens but nothing gets imported. Then When I try to mannually choode the folder to open in this case my CF card on the camers Im not given that option in the directory within Aftershot. Its as if the camers's not there.
afx
System_Drive: N/A
Post by afx »
lidiving wrote:USB.
That is the connection, not the mount point.
Where in the file system does Ubuntu show you the cam?
From your description it sounds like the cam uses some silly mode (PTP) instead of mass storage that is only available via some specific drivers.
Set it to Mass Storage mode. See page 319 of the manual (English PDF).
If the cam is not visible in the file system, AS will not see it. To make it visible in the file system, Mass Storage Mode is needed.
cheers
afx
lidiving
Post by lidiving »
No....thats not it...already checked. Just cant seem to get this to work in linux....
afx
System_Drive: N/A
Post by afx »
Well, if you have mass storage mode active, there should be a mount point in the file system...
cheers
afx
