When converting files from my Om-D E-M5 camera the program crashes frquently. If you put more than 3 in an outputbatch all stops and the program has to be restarted end the casche nuked, or the program returns with a memory error.
When doing the same thing with files from my Olympus Pen EP-1 there is no problems what so ever. I have allso noticed that when using the clone tool on the E-M5 files that it is not the target in the circle that is cloned - that cloned lies outside the circle...
I think the raw processing for E-M5 needs to be worked a lttle bit more on.
Regards
Olympus OM-D E-M5 file problem
Tornado
- processor: Intel CORE i7
- Video Card: On-chip GPU
- Hard_Drive_Capacity: 256GB SSD
Re: Olympus OM-D E-M5 file problem
I seem to be ok with EM-5 raw conversion & import. I'm running Win7 32-bit.
It is definitely not working right. When I try to process a OM-D file it is soooo slow... and If i use an outputbathc wit resizing the program stops working. I have to restart it and nuke the cache to get it working again. I hae tried wcompletely without plugins - Same problem. Tried without NN and sharpening - same problem.
I think it is back to the drawing board with OM-D E_M5 files
All of the above works fine with files from my Pen E-P1 camera.
Regards
Per
Regards
Per
