Not at all. Not only, it's plenty fast enough. I did my own testing with Lightroom in the VMware box (2 cpus + 3Gb RAM) and the catalog over the network on one computer vs another one fairly close (definetly not identical computer, core2duo + 3gb RAM but a slightly slower harddrive) and I couldn't see a difference in speed.Blrfl wrote:You may find that less than ideal.pgman wrote:roland65 wrote:...How to make LR work inside a virtual box AND the catalog on a network drive...
What are you switching to?
Re: What are you switching to?
Here is a new tutorial for running Lightroom 3.x or 4.x with Wine 1.5.17 : http://www.pentaxforums.com/forums/digi ... ell-3.html
This works well and is quite fast!
RB
RB
Yes it works very well ! Fast and reliable.
Here is a screenshot : LR 4.2 on fedora 17 64bits
http://i48.servimg.com/u/f48/13/98/61/29/captur28.jpg
Here is a screencast (5 IP at the same time. If doesn't work, try later, perhaps you'll be lucky)
http://dl.free.fr/eoq2a5Jiu
Thanks you so much Roland for that incredible work.
LR is now an ASP concurrent on Linux too. Wake up Corel and listen to us if you don't want a customers hemorrhage !
Darktable 3. Bye bye aftershot.
Thanks for the flowers! Now I'll try to see if Photoshop CS6 also works...
RB
RB
t3mujin
- motherboard: Asus P5QL-E
- processor: Core2 Quad CPU Q6600 2.40GHz
- Hard_Drive_Capacity: 1 TB
- Monitor/Display Make & Model: HP LP2475W
I wasn't that successful, It installed ok but fails to start. I'll clean up my wineprefix and start from scratch later
Code: Select all
err:module:import_dll Loading library comctl32.dll (which is needed by L"C:\\windows\\system32\\shell32.dll") failed (error c000007b).
err:module:import_dll Library shell32.dll (which is needed by L"C:\\windows\\system32\\winemenubuilder.exe") not found
err:module:LdrInitializeThunk Main exe initialization for L"C:\\windows\\system32\\winemenubuilder.exe" failed, status c0000135
err:module:DelayLoadFailureHook failed to delay load shell32.dll.SHGetFolderPathW
wine: Call from 0x7b84a4e4 to unimplemented function shell32.dll.SHGetFolderPathW, aborting
wine: Unimplemented function shell32.dll.SHGetFolderPathW called at address 0x7b84a4e4 (thread 000b), starting debugger...
err:module:DelayLoadFailureHook failed to delay load comctl32.dll.InitCommonControlsEx
wine: Call from 0x7b84a4e4 to unimplemented function comctl32.dll.InitCommonControlsEx, aborting
fixme:actctx:parse_depend_manifests Could not find dependent assembly L"Microsoft.Windows.Common-Controls" (6.0.0.0)
fixme:thread:GetThreadPreferredUILanguages 52, 0x32f8e8, 0x32fb64 0x32f8f0
fixme:thread:GetThreadPreferredUILanguages 52, 0x32f6d4, 0x32f950 0x32f6dc
p11-kit: couldn't load module: /usr/lib/i386-linux-gnu/pkcs11/gnome-keyring-pkcs11.so: /usr/lib/i386-linux-gnu/pkcs11/gnome-keyring-pkcs11.so: cannot open shared object file: No such file or directory
fixme:thread:GetThreadPreferredUILanguages 52, 0x32f734, 0x32f9b0 0x32f73c
fixme:heap:HeapSetInformation (nil) 1 (nil) 0
fixme:heap:HeapSetInformation 0x110000 0 0x32fa74 4
fixme:win:EnumDisplayDevicesW ((null),0,0x32f3b8,0x00000000), stub!
fixme:thread:GetThreadPreferredUILanguages 52, 0x32f494, 0x32f710 0x32f49c
fixme:shell:IShellLinkW_fnGetPath (0x15b248): WIN32_FIND_DATA is not yet filled.
fixme:shell:IShellLinkW_fnGetPath (0x15b2e8): WIN32_FIND_DATA is not yet filled.
wine: Call from 0x7bc4a220 to unimplemented function KERNEL32.dll.InitializeConditionVariable, aborting
wine: Unimplemented function KERNEL32.dll.InitializeConditionVariable called at address 0x7bc4a220 (thread 0009), starting debugger...
Unhandled exception: unimplemented function KERNEL32.dll.InitializeConditionVariable called in 32-bit code (0x7bc4a220).
Register dump:
CS:0023 SS:002b DS:002b ES:002b FS:0063 GS:006b
EIP:7bc4a220 ESP:0032e92c EBP:0032e990 EFLAGS:00000202( - -- I - - - )
EAX:00374d44 EBX:7bca9ff4 ECX:0000000c EDX:00000000
ESI:0032e938 EDI:05473c08
Stack dump:
0x0032e92c: 00000000 00000000 00ae4000 80000100
0x0032e93c: 00000001 00000000 7bc4a220 00000002
0x0032e94c: 00374e2e 00374d44 0000000c 054c0760
0x0032e95c: 054661d0 0032e980 78ab0269 00ae4000
0x0032e96c: 00000000 0000000c 054661d0 054c0760
0x0032e97c: 78ab02c1 0032e99c 78ab02d1 00000001
Backtrace:
=>0 0x7bc4a220 call_dll_entry_point+0x5f0() in ntdll (0x0032e990)
1 0x003a003c (0x054661d0)
2 0xffffffff (0x00135300)
0x7bc4a220 call_dll_entry_point+0x5f0 in ntdll: subl $4,%esp
Modules:
Module Address Debug info Name (121 modules)
PE 330000- 392000 Deferred agkernel
PE 400000- 5e0000 Deferred lightroom
PE 5e0000- 8a9000 Deferred ui
PE 8b0000- 998000 Deferred substrate
PE 10000000-10020000 Deferred asneu
PE 5d360000-5d36d000 Deferred mfc100enu
PE 70d00000-70e91000 Deferred gdiplus
PE 71590000-71617000 Deferred comctl32
PE 78050000-780b9000 Deferred msvcp100
PE 785f0000-78a22000 Deferred mfc100u
PE 78aa0000-78b5e000 Deferred msvcr100
ELF 7b800000-7ba2d000 Deferred kernel32<elf>
\-PE 7b810000-7ba2d000 \ kernel32
ELF 7bc00000-7bcc6000 Dwarf ntdll<elf>
\-PE 7bc10000-7bcc6000 \ ntdll
ELF 7bf00000-7bf04000 Deferred <wine-loader>
ELF 7d7ab000-7d7b4000 Deferred librt.so.1
ELF 7d7b4000-7d7cb000 Deferred libresolv.so.2
ELF 7d7cb000-7d815000 Deferred libdbus-1.so.3
ELF 7d815000-7d81e000 Deferred libkrb5support.so.0
ELF 7d81e000-7d823000 Deferred libcom_err.so.2
ELF 7d823000-7d84b000 Deferred libk5crypto.so.3
ELF 7d84b000-7d919000 Deferred libkrb5.so.3
ELF 7d919000-7d92b000 Deferred libavahi-client.so.3
ELF 7d92b000-7d939000 Deferred libavahi-common.so.3
ELF 7d939000-7d976000 Deferred libgssapi_krb5.so.2
ELF 7d976000-7d9d5000 Deferred libcups.so.2
ELF 7d9d5000-7d9da000 Deferred libgpg-error.so.0
ELF 7d9da000-7d9ee000 Deferred libp11-kit.so.0
ELF 7d9ee000-7da72000 Deferred libgcrypt.so.11
ELF 7da72000-7da84000 Deferred libtasn1.so.3
ELF 7da84000-7db48000 Deferred libgnutls.so.26
ELF 7db6e000-7db90000 Deferred imm32<elf>
\-PE 7db70000-7db90000 \ imm32
ELF 7dc35000-7dc4b000 Deferred dwmapi<elf>
\-PE 7dc40000-7dc4b000 \ dwmapi
ELF 7dc4b000-7dc7f000 Deferred uxtheme<elf>
\-PE 7dc50000-7dc7f000 \ uxtheme
ELF 7dc95000-7dc9c000 Deferred libxfixes.so.3
ELF 7dc9c000-7dca7000 Deferred libxcursor.so.1
ELF 7dd38000-7dd60000 Deferred libexpat.so.1
ELF 7dd60000-7dd98000 Deferred libfontconfig.so.1
ELF 7dd98000-7dda8000 Deferred libxi.so.6
ELF 7dea8000-7deb3000 Deferred libxrandr.so.2
ELF 7deb3000-7deba000 Deferred libxdmcp.so.6
ELF 7deba000-7debe000 Deferred libxau.so.6
ELF 7debe000-7dee0000 Deferred libxcb.so.1
ELF 7dee0000-7e016000 Deferred libx11.so.6
ELF 7e016000-7e01a000 Deferred libkeyutils.so.1
ELF 7e03c000-7e0c6000 Deferred winex11<elf>
\-PE 7e050000-7e0c6000 \ winex11
ELF 7e0c6000-7e160000 Deferred libfreetype.so.6
ELF 7e160000-7e17f000 Deferred libtinfo.so.5
ELF 7e17f000-7e1a1000 Deferred libncurses.so.5
ELF 7e1c5000-7e1c9000 Deferred libxcomposite.so.1
ELF 7e1c9000-7e1d3000 Deferred libxrender.so.1
ELF 7e1d3000-7e1d9000 Deferred libuuid.so.1
ELF 7e1d9000-7e1f3000 Deferred libice.so.6
ELF 7e1f3000-7e205000 Deferred libxext.so.6
ELF 7e205000-7e28a000 Deferred urlmon<elf>
\-PE 7e210000-7e28a000 \ urlmon
ELF 7e28a000-7e399000 Deferred oleaut32<elf>
\-PE 7e2a0000-7e399000 \ oleaut32
ELF 7e399000-7e3d6000 Deferred winspool<elf>
\-PE 7e3a0000-7e3d6000 \ winspool
ELF 7e3d6000-7e4b7000 Deferred comdlg32<elf>
\-PE 7e3e0000-7e4b7000 \ comdlg32
ELF 7e4b7000-7e4db000 Deferred iphlpapi<elf>
\-PE 7e4c0000-7e4db000 \ iphlpapi
ELF 7e4db000-7e506000 Deferred netapi32<elf>
\-PE 7e4e0000-7e506000 \ netapi32
ELF 7e506000-7e534000 Deferred secur32<elf>
\-PE 7e510000-7e534000 \ secur32
ELF 7e534000-7e5ee000 Deferred crypt32<elf>
\-PE 7e540000-7e5ee000 \ crypt32
ELF 7e5ee000-7e664000 Deferred rpcrt4<elf>
\-PE 7e600000-7e664000 \ rpcrt4
ELF 7e664000-7e76c000 Deferred ole32<elf>
\-PE 7e680000-7e76c000 \ ole32
ELF 7e76c000-7e780000 Deferred msimg32<elf>
\-PE 7e770000-7e780000 \ msimg32
ELF 7e780000-7e7b2000 Deferred ws2_32<elf>
\-PE 7e790000-7e7b2000 \ ws2_32
ELF 7e7b2000-7e9c5000 Deferred shell32<elf>
\-PE 7e7c0000-7e9c5000 \ shell32
ELF 7e9c5000-7ea30000 Deferred shlwapi<elf>
\-PE 7e9d0000-7ea30000 \ shlwapi
ELF 7ea30000-7ea92000 Deferred advapi32<elf>
\-PE 7ea40000-7ea92000 \ advapi32
ELF 7ea92000-7eb58000 Deferred gdi32<elf>
\-PE 7eaa0000-7eb58000 \ gdi32
ELF 7eb58000-7ec9a000 Deferred user32<elf>
\-PE 7eb70000-7ec9a000 \ user32
ELF 7ec9a000-7ecc0000 Deferred mpr<elf>
\-PE 7eca0000-7ecc0000 \ mpr
ELF 7ecc0000-7ecd9000 Deferred libz.so.1
ELF 7ecdb000-7ece1000 Deferred libxxf86vm.so.1
ELF 7ece1000-7ecea000 Deferred libsm.so.6
ELF 7ecea000-7ecff000 Deferred authz<elf>
\-PE 7ecf0000-7ecff000 \ authz
ELF 7ecff000-7ed72000 Deferred wininet<elf>
\-PE 7ed10000-7ed72000 \ wininet
ELF 7ef72000-7ef7f000 Deferred libnss_files.so.2
ELF 7ef7f000-7ef8b000 Deferred libnss_nis.so.2
ELF 7ef8b000-7efa5000 Deferred libnsl.so.1
ELF 7efa5000-7efae000 Deferred libnss_compat.so.2
ELF 7efae000-7efda000 Deferred libm.so.6
ELF 7efdc000-7efe0000 Deferred libxinerama.so.1
ELF 7efe0000-7eff9000 Deferred version<elf>
\-PE 7eff0000-7eff9000 \ version
ELF f72a0000-f72da000 Deferred liblcms.so.1
ELF f7413000-f7432000 Deferred mscms<elf>
\-PE f7420000-f7432000 \ mscms
ELF f7433000-f7438000 Deferred libdl.so.2
ELF f7438000-f75e2000 Deferred libc.so.6
ELF f75e3000-f75fe000 Deferred libpthread.so.0
ELF f7605000-f7623000 Deferred wintab32<elf>
\-PE f7610000-f7623000 \ wintab32
ELF f7624000-f7766000 Dwarf libwine.so.1
ELF f7768000-f778a000 Deferred ld-linux.so.2
ELF f778a000-f778b000 Deferred [vdso].so
Threads:
process tid prio (all id:s are in hex)
00000008 (D) C:\Program Files (x86)\Adobe\Adobe Photoshop Lightroom 4.2\lightroom.exe
00000025 0
00000009 0 <==
0000000e services.exe
0000001f 0
0000001e 0
00000018 0
00000017 0
00000015 0
00000010 0
0000000f 0
00000012 winedevice.exe
0000001c 0
00000019 0
00000014 0
00000013 0
0000001a plugplay.exe
00000020 0
0000001d 0
0000001b 0
00000023 explorer.exe
00000024 0
Woot. The patch works fine. winetricksing IE7 and copying the .dll wasn't needed here.
patrickh
- System_Drive: N/A
- motherboard: Macintosh
- processor: 2.93 GHz Intel Core i7
- ram: 4GB
- Video Card: ATI Radeon HD 5750 1024 MB
- sound_card: MacNone
- Hard_Drive_Capacity: 1Terabyte
- Monitor/Display Make & Model: iMac 27"
Just made the move to LR, after testing almost everything out there. My departure makes no difference to them, I am only one user and my loss will not break the bank. But I loved ASP and the enthusiasm of the contributors (plugins, help etc.) and it was very reluctantly that I was forced into the opinion that Corel either does not have the resources to support and develop the product and/or does not have the will. I will miss this forum.
patrickh
patrickh
You have a problem with a missing comctl32 dll...t3mujin wrote:I wasn't that successful, It installed ok but fails to start. I'll clean up my wineprefix and start from scratch later
Code: Select all
Try again with a fresh .wine directory. Don't forget any step!
RB
You need IE7 for the web module and also probably the Book module.teekay wrote:Woot. The patch works fine. winetricksing IE7 and copying the .dll wasn't needed here.
Copying the dll fixes problems with some dialogs (e.g. the remove dialog).
RB
Jarkod
- System_Drive: N/A
- motherboard: Asustek
- processor: Intel
- ram: 8 GiB
- Video Card: Asustek
- sound_card: Intel
- Hard_Drive_Capacity: plenty
- Monitor/Display Make & Model: LCD
So there's two of us. I was even more reluctunt to switch to LR because not only had I buy LR but also MS Windows - system that I haven't had on my computer since decade. I invested quite a lot in Bibble (the program itself and BSG) and AFS (and ASG), both time and money but the recent moves of Corel (or lack of them) literally forced me to look for a different software. AFS was $79 when I bought it. LR was $95 and Windows $113, what gives $208 - almost three times more then one AFS license and I could have spent it on Corel product. Hey, Corel, your customer care policy is beginning to be profitable (for others).patrickh wrote:Just made the move to LR, after testing almost everything out there. My departure makes no difference to them, I am only one user and my loss will not break the bank. But I loved ASP and the enthusiasm of the contributors (plugins, help etc.) and it was very reluctantly that I was forced into the opinion that Corel either does not have the resources to support and develop the product and/or does not have the will. I will miss this forum.
patrickh
The only thing I regret is I didn't do that move earlier.
I have switched too to LR. So it is way more then just one customer lost now even though I am not a commercial loss, I had a NFR license. Still it is a sign for Corel that they can't even retain a customer who does not pay. The quality of my pictures comes first. LR4 has made soooo much improvement vs. LR3.
I have 100% stepped into it with the great book from Scott Kelby on LR4. This software has everything I need, with no need of any plugin. Or maybe just Nik plugins, just because they save time when looking for a great impact photo.
Capture One v7 came out recently, and after giving it a try I bought a license, and never looked back. It's slow enough that Aftershot looks to be from the lightning future, but wow that output. No pink highlights, far better sharpness, and better colour than lightroom. I really liked the way AFS blazed through my photos, but it was always the blunt instrument: too eager to blow the highlights, blow colour channels, and produce harsh images. Subtlety was not its forte. AFS lacked the colour smarts I could find in Lightroom, but Lightroom didn't offer the editing tools (or the speed) that AFS did (plus I loath Adobe for reasons), so I stuck with the AFS.
But now, the image quality I get from Capture One is just staggering. I'm going back through photos I thought were perfect via Bibble 5 or AFS, and doing them again. Every once in a while the AFS version wins, but the majority of my photos are better with C1. And, after learning C1 more thoroughly, even the AFS-favoured photos are coming good.
Like any software there are limitations, and @#*% is it ever slow!! But I think the pics look better. The models I shoot think the pics look better. My website galleries look better now. We'll see how AFS improves if Corel ever releases an update, but until then it's C1 all the way for me.
afx
- System_Drive: N/A
- Video Card: FirePro 4900
On what CPU and do you have a fast GPU?NFG wrote:Like any software there are limitations, and @#*% is it ever slow!!
I always felt that C1 colors are lacking (Nikon NEFs) but what really pissed me of with C1 v6 was that it showed the embedded JPGs of my Oly XZ-1 but did not tell me.
Can the output recipes be used as a substitute for multiple queues?
Regional editing still seems to exclude nose reduction which looks quite silly.
cheers
afx
i7 2600 @ 3.4GHz, and an 8800GTS.afx wrote:On what CPU and do you have a fast GPU?
I'm finding that C1 is very much the middle ground between AFS and Lightroom, with a lot of restrictions on how far I can push things (AFS let me get into trouble too easily) but more freedom than Lightroom.afx wrote:I always felt that C1 colors are lacking (Nikon NEFs) but what really pissed me of with C1 v6 was that it showed the embedded JPGs of my Oly XZ-1 but did not tell me.
The same goes for the local edits you mentioned. There's only one edit tool (the airbrush), and I miss the polygon selector in AFS like crazy. It's cumbersome, but it's just one of those tradeoffs you need to make with any software. And yeah, there's a limited number of things you can do with a local edit layer, but again there's a lot more tools available than Lightroom offered. This ability to apply any of the available tools to any layer was a seriously excellent function of AFS, and one of the only things I unreservedly miss.
I'm not really sure, I don't mess with that a lot. I only run one recipe at a time, and I never queue things. One day I'll probably need to know this, but I've not had to dive into it yet. I know I've seen some people going on about it on the C1 forums...afx wrote:Can the output recipes be used as a substitute for multiple queues?
tomsi42
Nose reduction? Sounds like a killer featureafx wrote: Regional editing still seems to exclude nose reduction which looks quite silly.
On a more serious note; I often hear that Capture One is favored by model photographers. I have the C1 6 basic version and found it a capable tool, but it lacks too many things; some of those things are also missing in the Pro version.
I don't think there is any programs out there that can match ASP's speed. ASP is usable on a AMD E-450 based system if you are a little patient; nothing else is.
