Can import one time and can't next time. HELP!!!!
smcdl
Post by smcdl »
One day I can import form a DVD and next time I can't. What the heck is wrong? :evil:
GeorgeW
Post by GeorgeW »
was it the same DVD?
What type of DVD are you importing? Retail DVD, a DVD you burned to ±R/RW disc, a DVD from a DVD Recorder unit, other???
George
smcdl
Post by smcdl »
DVD that has been burnedd on DVD recorder
GeorgeW
Post by GeorgeW »
was it the same disc, or a different disc?
was it the same type of disc -- like a +R each time? Or was one a +RW, and the other a -R, or some mixture like that?
did you "finalize" the disc in the DVD Recorder?
George
smcdl
type of disc
Post by smcdl »
I use DVD-RW and DVD+RW. I tried to trace it to brand, type, etc. and nothing makes any sense on why one works one time and not the next but does the next. What I am doing is recording TV shows to edit and send to my son who was deployment to the Middle East.
GeorgeW
Post by GeorgeW »
DVD-RW vs. DVD+RW discs -- one might be readable right out of the DVD Recorder, and the other one might require "finalizing" before it can be read by your computer.
I suspect the +RW disc can go right from your recorder to your computer. I think your -RW disc might require "finalizing" (but check in your user manual, or just try it to see if that's the case).
George
smcdl
Post by smcdl »
I am very aware of what needs to be done to the discs This is what's frustrating. One time it imports and the next zippo.
ploggy
Post by ploggy »
you might need to restart the computer after importing the first DVD. I had this problem trying to import DVD-VR which uses UDF format. When I insert the disc in the drive, Windows Explorer can see the files. After importing it to DMF, the second disc i inserted is no longer accessible bt Explorer. So what I did was to save the project, restart the computer, then open the project and import the second disc.
the UDF driver may not be closing properly when the first disc was ejected so the second disc becomes an unreadable UDF disc.
anyone have other thoughts on this? i might be wrong about the udf driver.
