Acer K11 and MPEG formats
daddog
Post by daddog »
Just bought the Acer K11 projector (great little projector I might add), but I am having some troubles with the video formats it supports.
I was told to use 480P@30Hz or 576P@25Hz. Do we have those? Here is my drop down with VSX4
I was also told the K11 would play:
Support MJPEG D1@30fps
(480P@30Hz/576P@25Hz)
Support MJPEG4@SP
D1@30fps(480P@30Hz/576P@25Hz)
Support H263, H264@Baseline
Support AVI, MOV movie formats
Support 3gp movie format
Any way to customize one? The iPodH264 worked just fine, but that was the only one. I tried them all under the MPEG-4 options. The iPodH264 is way too small as I am using this for some small group presentations. Does VS X5 offer more options (AVI or MOV?) that might be compatible with the K11 formats and be something larger than an iPod?
Thanks in advance. :)
aka James or dd :)
MB Gigabyte GA-EP45T-UD3P
CPU Intel 2 Duo E8500 3.16GHz
Windows 7 64bit
GeoForce GTX 260
4GB of RAM
DirectX 10
LiteOn DVD Burner SOHW-1693S
Sony HDR-CX550V camcorder
http://www.332nd.org/
Re: Acer K11 and MPEG formats
They're blinding you with science! :lol: "480p/30Hz" in fact means NTSC 720 x 480, 30 frames per second and the p stands for progressive or frame based. (The other lot "576p/25Hz" is the PAL equivalent -- 720 x 576, 25 frames per second, and again frame-based or progressive.) So you would presumably make a video using those properties e.g. a slideshow which can always use frame-based or a video using frame-based or progressive. A customised DVD template should achieve that, as will any of the other formats they list.
daddog
Post by daddog »
lol Thank Ken. :) I will try the DVD MPEG2 720x480 option and see how that works. :)
aka James or dd :)
Windows 7 64bit
GeoForce GTX 260
4GB of RAM
DirectX 10
daddog
Post by daddog »
Oh I should ask...
How did you know that Ken? Do you have a chart or spec sheet I could reference or was that info in your head? :)
aka James or dd :)
Windows 7 64bit
GeoForce GTX 260
4GB of RAM
DirectX 10
Sorry, it was in my head. But it was pretty obvious, and the information - while presented in a slightly different - is nonetheless some of the most basic when it comes to video formats...
