Bye Bye AfterShot
stefanve
operating_system: Linux
processor: Intel Core i7 - 3610QM
Video Card: Nvidia GT630M
Hard_Drive_Capacity: 500GB
Re: Bye Bye AfterShot
Post by stefanve »
afx wrote:Guess how it does that?
Eric designed his own multitasking kernel because standard frameworks did not perform well enough for his purposes. AS does not use any standard framework for that.
A kernel in this case is a name for a module that is responsible for multithreading and memory management. While it bares the same name it is no where near as complex as a OS kernel.
Like I said before this is not uncommon to do (especially in a c/c++ app) since it is far easier to optimize if it is your own code because you can tailor make it for your needs. If you use some framework it will not be optimized for your needs and performance will be not as good, so in a application where footprint and speed matters almost every one will make there own "kernel" code.
Corel is the owner for almost two years, it is really not unreasonable to think that this is a ample amount of time for knowledge transfer and in fact it could easily be a term in the contract (that the old team is responsible to provide ample knowledge transfer).
As for the bad rep of Corel, unless some one has real examples, instead of repeating false claims about WP and PSP, there is no factual base for this. Really people use the internet before making statements like, "Corel killed WP when WP was the best in its game", as it will only take you 2 minutes to find out that is is BS.
So again there is still no valid reason given by any one not to give Corel the benefit of the doubt.
I can understand that your are upset since Corel let go of the people you care for, and you are not be given the same recognition by Corel as you used to have from the old team ( I suspect you now have made sure you never will). The only thing you have done is spreading FUD with out giving any facts at all, I think it is shameful since you are a moderator, so your words have more weight, and should not have screamed murder with out any proof. Especially since all your other posts and works are so well balanced
If you feel you are totally right about it please give us some proof.
Stefan
jknights
operating_system: Mac
motherboard: Apple
processor: Intel 3.08GHz Dual processor Quad Core
ram: 24GB
Video Card: ATI Radeon X1600
sound_card: Intel HDA
Hard_Drive_Capacity: 6TB
Monitor/Display Make & Model: Apple Display
Post by jknights »
Are you a Corel employee ? :lol: It seems like you are trying to justify the decisions of Corel's management.
The public only knew about the Corel acquisition of BibbleLabs just under one year ago.!
I have the original email to me as a Bibble Beta Tester saying that I now had to sign a Corel NDA. This is dated, 23 September 2011. I guess that there had been some spade work before that and maybe the acquisition was started up to 6 months prior so being generous it is 18 months maximum.
OK so pedantic details done.
Stefan
Stefan,
I used PSP before I used Photoshop when it was a JASC product. Likewise I used the DOS and Windows versions of WordPerfect. The Windows version was very good, it allowed active embedding of a spreadsheet that actually updates itself if you change figures in paragraphs that are linked to cells!! Something that in 1996 was cool but still in 2012 Word doesnt seem able to do :lol:
Back to business.
Since you seem to be so pleased that Corel have closed on ASP what do you propose to run in the future on your Linux environment for RAW file conversion?
If you buy a new camera released after Nikon D800 (3-6 months ago) then forget using it in RAW mode as there will be no updates to RAW support if Corel have pulled the plug on development.
For me this wont work as I update my cameras on a two year cycle and I buy a new camera every year.!! So in one year I am in a position of not being able to you ASP. So I might as well switch to Capture Pro and Adobe ACR now, this effectively kills ASP which is what afx and others have been saying.
Likewise in the Beta Testers forum I have tested every plugin on the Mac environment and interacted with the developers over bugs and in consistencies as well as working with the Bibble/Corel development team in an effort to improve and extend the functionality of the ASP SDK.
This SDK is in my opinion the big differentiator (apart from ASP/Bibble high speed RAW conversion) between ASP and other RAW processors. Without the SDK then it is just another RAW processor but add-in in the plugins then you have a fast and efficient workflow to output client images in a consistent and high quality fashion.
I think you need to really think out you arguments and understand the facts before trying to denigrate opposing arguments.
Still learning after all these years!
afx
System_Drive: N/A
Video Card: FirePro 4900
Post by afx »
stefanve wrote:A kernel in this case is a name for a module that is responsible for multithreading and memory management. While it bares the same name it is no where near as complex as a OS kernel.
Why are you arguing about code that you have never seen and whose creators you never talked with? You know nothing about the internal structure of AS.
You are making boatloads of assumptions that are far off.
As I mentioned previously, it is really not hard to contact the original developers. Ask them.
Maybe you should check your references. It is barely one year.
And knowledge transfer requires someone to transfer to.
cheers
afx
stefanve
Post by stefanve »
jknights wrote: Are you a Corel employee ? :lol: It seems like you are trying to justify the decisions of Corel's management.
Most people that don't have any facts to sustain there claims, will revert to "conspiracy theory's". I have been consistent in asking for facts to sport the claim that ASP is over and that I and any body else that bought should be worried.
if afx says "Everything will be dead...." he should back this up with facts, and he or any one else have failed to do so. There for I call him out to give some, and give my opinion that since there are no facts we should give Corel the benefit of the doubt. It is really that simple.
jknights wrote:
The public only knew about the Corel acquisition of BibbleLabs just over one year ago.!
afx wrote: Maybe you should check your references. It is barely one year.
again it is really easy to do some research on the internet
http://support.bibblelabs.com/forums/vi ... 84&t=19655
clearly states that is was bought early last year (post is from Jan 2012) so your NDA date is irrelevant, yes it is not two years (I said almost two years), it is around 20 months or so) if your only argument is that my argument of knowledge transfer it is not true, because it was a bit less than two years, you don't have any at all.
jknights wrote: Stefan,
I did use WP on DOS and windows as well that's why I knew your statements where false, because I remembered how bad it performed, and how bad the integration was on windows even with cool features like the "underwater screen"
from wikipedia:
While WordPerfect 7 contained notable improvements over the 16-bit WordPerfect for Windows 6.1, it was released in May 1996, nine months after the introduction of Windows 95 and Microsoft Office 95 (including Word 95). The initial release suffered from notable stability problems. WordPerfect 7 also did not have a Microsoft "Designed for Windows 95" logo. This was important to Windows 95 software purchasers as Microsoft set standards for application design, behavior, and interaction with the operating system. To make matters worse, the original release of WordPerfect 7 was incompatible with Windows NT, hindering its adoption in academia. The "NT Enabled" version of WordPerfect 7, which Corel considered to be Service Pack 2, was not available until Q1-1997, over six months after the introduction of Windows NT 4.0, a year and a half after the introduction of Office 95 (which supported Windows NT out of the box), and shortly after the introduction of Office 97.
So yeah Corel bought NOT a competitive product .
As for you using PSP before Photoshop that is irrelevant Corel bought PSP half a year before PS CS3 was released, nuff said ;)
Back to business :D
jknights wrote: Since you seem to be so pleased that Corel have closed on ASP what do you propose to run in the future on your Linux environment for RAW file conversion?
Again you don't have any facts to support this claim! Corel said that they would continue support for Linux, Mac and windows and nobody on this form has any facts given to believe they will break this promise
jknights wrote: If you buy a new camera released after Nikon D800 (3-6 months ago) then forget using it in RAW mode as there will be no updates to RAW support if Corel have pulled the plug on development.
They killed the original team, but again there is no evidence that this means they killed development, as other people has been saying it could be very well the reason that they have been let go (slow to update and bugs fixes). But we don't know since we don't have any facts. I would say just wait for the next release and see what it brings, and lets see in how the support will be (I'm waiting for RX100 RAW support)
jknights wrote: Likewise in the Beta Testers forum I have tested every plugin on the Mac environment and interacted with the developers over bugs and in consistencies as well as working with the Bibble/Corel development team in an effort to improve and extend the functionality of the ASP SDK.
I think this is a very cool feature as well! Don't know what this ads to the discussion, but yeah it's cool
jknights wrote: I think you need to really think out you arguments and understand the facts before trying to denigrate opposing arguments.
Yes please do that! :)
afx wrote: Why are you arguing about code that you have never seen and whose creators you never talked with? You know nothing about the internal structure of AS.
Because software design in not some thing arcane, allot of good design principles are used one way or the other is every quality software. When most people hear the term kernel they think about the Linux kernel or OS kernels in general, you don't need to see the code to understand that to write a kernel for a program that mimics all functionality of the host OS kernel is unnecessary, stupid, and for the most part undo able. As you are clearly not a programmer by trait I can understand the confusion, but just ask your friends if they have done things that at a meta level/ design level aren't done in any other program, some parts may or may not be 'special' but there are just so many ways to do this stuff right. If you build a high performance application like ASP you have no choice than to make a 'kernel' your self.
Since we are running in circles I will not continue this discussion. You and afx don't give any facts on why ASP is dead and why I should be worried.
Your "history" lesson on why I should belief that Corel kills software, was easily falsified, if you only counter argument is that you have used it (WP) and it had/has cool features, you don't have an argument.
afx constantly make wiled claims at the mythical difficult to learn code base, that some how ASP is so difficult that it is impossible to learn, even though after a bit spend on the internet (linkdin) they have had employees that build nice things and only worked there for a couple of years. Some how these guys are so good in programming but at the same time write code that is incomprehensible by mortals. and because of that every thing is dead......
So we are back at where we started, you make claims without giving facts, I ask for facts, you don't have any, I say give Corel the benefit of the doubt since there aren't any facts not to do so.
as a side note: I belief afx when he told us that the team has been dissolved, even if he is the only reference of this claim
Stefan
PS afx I hope you will update your guide after the next release as I'm planning to buy it
afx
System_Drive: N/A
Post by afx »
stefanve wrote:
afx wrote:Maybe you should check your references. It is barely one year.
You might want to learn the distinction between early and earlier...
Who mentioned an NDA date?
cheers
afx
stefanve
Post by stefanve »
[/quote]
You'r right I didn't read carefully , I was side tracked by http://www.siliconhillsnews.com/2012/01 ... bble-labs/
which says "How do you keep an acquisition quiet for almost a year?" than I found the post.
afx wrote: Who mentioned an NDA date?
jknights
Stefan
SteveCase
System_Drive: N/A
motherboard: ASRock 990FX Extreme4
processor: AMD FX-8350
ram: 16.0 GB
Video Card: GTX 550ti
Post by SteveCase »
This could be off topic and within topic at the same time....
Now a thought. With the flurry of discounts that Corel is offering at this time. One could easily suspect that new "paid" versions of everything are on the near horizon.
What if during this approx. 1 year time span they figured out how to merge PSP and ASP into integrated software that actually could run on all 3 OS's. That would put them slightly more than a leg up on Adobe and way ahead of GIMP. One sentence from that post from Jeff has always been in the back of my mind....
"I’m now running product development for Corel’s new photo workflow solution that is based on the core Bibble technology."
I could never quite relate this comment to the B5-ASP change over. Always thought that there was some other product involved. More like the Photoshop/ACR combination.
Steve in Seattle,WA
stefanve
Post by stefanve »
SteveCase wrote:This could be off topic and within topic at the same time....
Although that would be cool, not to mention an impressive engineering feat, I think he meant AS
brucet
operating_system: Windows 8.1
Post by brucet »
I just love these debates.
I'll sit back and give Corel a few months to prove who is right and who is wrong.
Then I'll sit back and wait to see who is man enough to admit to being a wee bit wrong with their arguments.
regards
Dutchmm
System_Drive: N/A
motherboard: Asus 97
processor: Intel i7 4785T
Video Card: Onboard Intel
sound_card: Intel AC97
Hard_Drive_Capacity: 2.5TB
Monitor/Display Make & Model: Philips 28"
Corel programs: ASP 3 Pro (and 2 and 1 before)
Post by Dutchmm »
It's been suggested that Corel would kill off sales of their current product if they were to announce the features of the new version/update/whatever.
I can see a way around this.
Let them run a beta of the new software in a group open, and restricted to, currently registered owners of AS, who are prepared to give up any rights under the 30 day money back deal. That would allow them to:
  • Boast about the new bells and whistles only to those who had already paid their old license money
    Restore confidence among those thinking of emigrating to LR land
    Still the flow of public execration in this forum, which can hardly be doing sales of AS any good.
    Enable Corel to reconnect the beta team with the developers - it is clear from this and other AS oriented fora that many beta testers feel they have lost contact with the developers (wherever they may be), and confidence in the devs' ability or desire to fix the bugs that they have reported
    Hell, it might even ensure that the new software really works when it goes on sale
No company is exempt from making mistakes. What differentiates the good from the rest is how they learn from them.
So I am happy to volunteer to be NewBeta #1. If Corel has any listeners on this forum ...
jknights
motherboard: Apple
ram: 24GB
Post by jknights »
Dutchmm wrote:It's been suggested that Corel would kill off sales of their current product if they were to announce the features of the new version/update/whatever.
Well if they can then let's hope that they want to and will.
Very true. :-)
I am happy to continue to use and test ASP but....
We need to be aware that a RAW processor stands by its ability to accurately process RAW files.
At present I really need support for the Fuji XPro1 RAW files.
I still await for a solution from Phase One in Capture One, so I have to use SilkyPix or RAW Photo Processor or DCRAW which give superior results to the support provided in LR and ACR from Adobe. The Adobe LR and ACR results are OK for most images but occasionally seem to have a major glitch and produce areas in the green that have a watercolour effect. Adobe have acknowledged this.
kumsa
System_Drive: N/A
motherboard: Dell Vostro V131
processor: i5 2.4 Ghz
ram: 8 G
Video Card: Nvidia
sound_card: Dell Laptop
Hard_Drive_Capacity: Terabytes
Monitor/Display Make & Model: Dell U2312HM, Acer
Post by kumsa »
Wow. A lot of passion in these posts. Really, though, I haven't heard anything official from Corel, and they aren't blind to these posts. I don't know the circumstances by which any development team was let go, but it could just as well have been a business decision to consolidate costs to support the product.
simico
System_Drive: N/A
Post by simico »
Hilarious.
Corel acquiring Bibble labs = sh!tloads of $
Purchasing ASP license after release = €14,99
Watching ASP fanboys' 180 degree turn = priceless
Ok, time to go back to LR4 to develop today's shots.
nyukuri
ram: 4GB
Post by nyukuri »
+1
grooveman
System_Drive: N/A
Post by grooveman »
This is indeed disturbing news...
I am sorry to hear about the bibble team... it must be hard to see your baby man-handled like this, and to be utterly out of the loop.
I can only hope that Corel will do ASP and its linux base justice... though I'm guarded on that front. If we have any luck, maybe some of the developers that were sacked will donate some time to darktable or to rawtherapee. It seems to me that those solutions were gaining fast on what B5 had to offer. With a little push, maybe they will catch up.
I'll give it a few months, and if it looks like ASP is in good hands, then maybe I'll stick it out for a while... if not, then I think they have just about sealed the Adobe Monopoly for image processing (and screwed over the linux base yet again...)...
