I would have looked it up in Help, but most of the time I'm unable to access Help. I get an "Unable to connect to server" error. Does anyone else get this or have a related problem? Is there a solution?
Many thanks.
Thank you very much for your post as it clearly states that Corel is not worth its price and how elitist and insulting their employees are.Simone Corel UK wrote:Re: ... I don't want CMYK separations. I just want to save in CMYK mode, as can be done in Photoshop.
PSP has always been a RGB program and can't do the same as 10x more expensive Photoshop. Because of the new image engine, PSPX4 opens CMYK pictures with a similar RGB colour space. Using a CMYK colour profile will crash PSP. There is no way to turn PSP into a Photoshop replacement. If you need CMYK, buy professional programs like Draw (Photo-Paint) or Photoshop.
I am not sure this meets the requirements you have for the images you want to save as CMYK but there are online conversion tools such as this one located here: http://www.rgb2cmyk.org/fotojrb wrote:That one I know, but I don't want CMYK separations. I just want to save in CMYK mode, as can be done in Photoshop.
YikesCyberDreamLady100 wrote: Corel should seriously consider dismissal of personnel with such attitudes as yours.
Offending the client is definitely not the right way to get your point across and highly unprofessional.
Were I you I would not post that I work for the company.
In your case it is not a very intelligent thing to do given your lack of skills in customer relations.
Thank you very much for your post as it clearly shows how self-centered and insulting some users are.CyberDreamLady100 wrote: (Deleted)
Once you've used Image...Split Channel...Split to CMYK, simply reverse the procedure by using Image...Combine Channel...Combine from CMYK. That will create a new image that is similar to the CMYK "Soft Proof" option found in Corel PhotoPaint.fotojrb wrote:It's time for my annual conversion of a couple of files to CMYK, and I've forgotten how it's done.Would someone be so kind as to remind me? (The last time I did it I was using X2.)
