Batch renaming original files only renames a single file
Bugs & Suggestions
pantarhei
operating_system: Linux
System_Drive: H
Post by pantarhei »
When I try to rename original files contained in a batch, only a single file gets renamed.
I am following the instructions described in http://product.corel.com/help/AfterShot ... brary.html.
First I select all thumbnails with [Ctrl] + [a]. All thumbnails in the folder have a yellow border now.
Then I press [F2] for rename version. I enter a name such as "2012-smith-[4jobseq]" (without quotes). "Rename all Versions derived from Master Versions" is checked -- or not, does not make a difference and should not make in this case.
Then I press the OK button.
Only a single file gets renamed. In the example: "2012-smith-0001.CR2" (when the job sequence is set accordingly).
further info:
- the photos have been edited and rated
- renaming of all files in a folder worked once
I thank you very much for your suggestions. If it is a bug, I thank you for fixing it.
following system information:
Code: Select all
Application vers.: 1.0.1.10
Product Name: AfterShot Pro Registered
Built on:     Sun Apr 1 2012
Platform:     Linux
Language:     en
App Path:     /opt/AfterShotPro/bin/AfterShotPro
System Home:  ../supportfiles
User Home:    <my home folder>/.AfterShotPro
Prefs Home:   <my home folder>/.config/Corel/AfterShot Pro.conf
Processors:   4
CPU Threads:  4
I/O Threads:  1
B. In-flight: 2
RAM:          7783 MB
SIMD Version: SSE2
Build Mode:   Release
Issue:        Ubuntu 12.04 LTS \n \l
Kernel:       Linux version 3.2.0-26-generic (buildd@batsu) (gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) ) #41-Ubuntu SMP Thu Jun 14 17:49:24 UTC 2012
====================  Plugins  =====================
      Name:
Identifier:
   Version: 1.0.0
      Path:
Identifier: sph.SiliconBonk
   Version: 0.33.0
      Path: <User Home>/Plugins/Silicon Bonk.afplugin
Identifier: com.corel.vigne
   Version: 1.1.0
      Path: <User Home>/Plugins/Vigne.afplugin
Identifier: sph.waveletsharpen
   Version: 1.34.0
      Path: <User Home>/Plugins/Wavelet Sharpen3.afplugin
      Name: Black and White
Identifier: com.corel.BlackAndWhite
   Version: 1.0.0
      Path: <System Home>/plugins/Black and White.afplugin
Identifier: com.corel.equalizer
   Version: 1.0.5
      Path: <System Home>/plugins/Equalizer.afplugin
Identifier: com.SMP.Nostalgia
   Version: 1.0.8
      Path: <System Home>/plugins/Nostalgia.afplugin
EOS
System_Drive: N/A
motherboard: Gigabyte
processor: Core i7-3930K
ram: 12GB
Video Card: Nvidia
Monitor/Display Make & Model: 2x Samsung SyncMaster 21 inch
Re: Batch renaming original files only renames a single file
Post by EOS »
i get the follow also on 1.0.1.10 linux version:
original names:
"test-2012-smith-0009.cr2" / "test-2012-smith-0010.cr2" / "test-2012-smith-0011.cr2" / "test-2012-smith-0012.cr2"
i renamed with "test2-2012-smith-[4jobseq]" :
"test2-2012-smith-0013.cr2" / "test2-2012-smith-0014.cr2" / "test2-2012-smith-0015.cr2" / "test2-2012-smith-0016.cr2"
conclusion:
i'm not able to restore the jobseq to start from 0001.
afx
System_Drive: N/A
Video Card: FirePro 4900
Post by afx »
pantarhei wrote:When I try to rename original files contained in a batch, only a single file gets renamed.
Switch off Multiview.
cheers
afx
afx
System_Drive: N/A
Post by afx »
EOS wrote:i get the follow also on 1.0.1.10 linux version:
So how is this related to the starting post of the thread which discusses a completely different issue?
original names:
conclusion:
Form what you wrote, that is definitely not discernible.
You might want to post a screenshot the rename dialog.
cheers
afx
