I am trying to create a movie with Corel Video Studio Pro with imported images that I have created in a 3D program! The framerate should be 24frames/second in the movie but it looks like
I can only get down to a image speed of 0.1 second or 10 frames/second by editing each images and then reduce duration time.
Is it impossible to get the duration time to 0.0417 that is about a speed of 24 frames/second?
If it is impossible maybe something for the wishlist to the future!
Next quistion is is it possible to somewhere in the settings change the duration time for images so
you don't need to edit each images each time!
It can be hard if you have over 400 images to edit!
Thank you and I love Corel!
Alf
How to create an animation from 3D Images?
alfhak712
- motherboard: Asus Rampage II Extreme
- processor: Intel Core i7 950 LGA1366
- ram: 6Gb
- Video Card: Nvidia GTX285
- sound_card: Soundmax Integrated Digital HD Audio
- Hard_Drive_Capacity: 800Gb
- Monitor/Display Make & Model: Compac MV920 + HPv72
Re: How to create an animation from 3D Images?
Hello and welcome.
When you change the image duration using the 'Edit >> Change photo/color duration' option note that the final figure in the row is frames - not seconds - so you can set to 1 frame which is 1/30 or 1/25 th of a second depending on which TV system you are using.
Regarding a default setting for the timing - there is good news and bad news - the good news is that if you go to 'Preferences' (F6) and select the 'Edit' tab at the top you will see a setting for the default color/photo duration - the bad news is that you can only set a minimum of 1 second in there, so you will still have to manually adjust each clip.
alfhak712
- ram: 6Gb
Thank you very much for quick reply!
Ok, so it was frames and not seconds!
Alf
Alf
