VS ProX 4 No sound in project form
joneshayes
motherboard: Gigabyte
processor: Pentium R Dual Core CPU E5800 3.20 GHz
ram: 2.0 GB
Hard_Drive_Capacity: 500 GB
Monitor/Display Make & Model: Flatron L1951S
Post by joneshayes »
When I insert a video to the timeline the only way I can have sound playback is to open the sound mixer. I had this happen once before and I reformatted my hard drive and re-installed everything and It worked fine for a while but now the problem is back. What is causing this to occur. Even when I insert a sample sound into the music track I get an error message when trying to play the clip.....Unable to play the file (16804:2:1)......and it won't play in project mode unless I use the sound mixer. HELP!!!!!
DVDDoug
Moderator
Re: VS ProX 4 No sound in project form
Post by DVDDoug »
Are you simply opening the mixer, or are you changing something? (I suspect that another application on your computer is messing with your mixer settings, or with your sound driver.)
Does the mixer fix that problem? What format is the audio file?
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
joneshayes
ram: 2.0 GB
I'm not changing anything.I used to be able to put a sound file (.wav) in the music or voice line and it would play in project or clip[ form. Now the only way to hear the file is to open the mixer.
teknisyan
processor: Intel Corel i5
ram: 4 GB
sound_card: Realtek HD Audio
Post by teknisyan »
There are many reason why this happens if you were able to hear or play audio before then you may want to reset the program to its default state.
To do that, just follow the steps at http://corel.force.com/index/articles/e ... y-Defaults
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
joneshayes
ram: 2.0 GB
Next option, that did not work.
UptownCheese
motherboard: asus p67 pro
processor: intel
Video Card: ati 6870
sound_card: onboard
Hard_Drive_Capacity: 7 tb
Monitor/Display Make & Model: asus
Post by UptownCheese »
I feel your pain. There are more than a couple sound issues with this program and the answer is they don't know. Good Luck
