Close to TWO YEARS LATER and still no reply or solution to this. Can you believe this? SP3 didn't solve the problem.MysticNitekatt wrote:Well, I know I'm up to day with my window 7 and all drivers, so that can be eliminated. I've in fact did 2 reinstals of windows 7 and 2 different clean installs of the program.lata wrote:Hi
Sorry you have not managed to sort the problem, as i mentioned i am unable to simulate the problem, it just works for me.
Would have been nice if others commented to see how many are affected.
It may well be only your system that this is happening to.
I still suspect there may be an issue with the install disc but unable to determine what.
As far as I can tell (and I haven't tried everything) Burning direct seems to be working, and basic editing,fx and rendering seems to be working in Mepg2 at 4:3. However, considering the cost of the software there should be better troubleshooting tools and support and I should not have to wait around till god knows when for the next patch, if there is even a patch for this problem.
There's an issue, and support and engineering have been "working on it", but yet I've not been offered any possible solutions to try or any troubleshooting advice, or even a work around.
STILL "Test Before Burning" Not Working in X4 Pro Update
MysticNitekatt
- motherboard: Dell Inc. 04GJJT
- processor: 3.10 gigahertz AMD Athlon II X4 645 Multi-core
- ram: 4GB
- sound_card: ATI High Definition Audio Device i
- Hard_Drive_Capacity: 1TB
- Monitor/Display Make & Model: DELL E157FP
Re: STILL "Test Before Burning" Not Working in X4 Pro Update
"In Space, No One Can Here You MEOW!"
Since Corel no longer consider X4 as a supported product one thing for certain is that there will not be a patch or update to fix your problem now.
Only Corel supported versions of VideoStudio now are X6 and X7.
A post from the past.
Well Corel do seem to have addressed the problem for X6 and X7 in that they appear to have removed the option to “Test before Burning”.
At least I cannot see the option available.
By the way what type of discs were you using? did you actually try different types.
If you were using DVD – + RW they do not support Test before Burning, at least not the make I tried.
I have to say that I never use the Test Before…. I always burn an iso and play that to view quality
Then burn the iso to disc.
MysticNitekatt
- ram: 4GB
Using DVD-Rs (Good stuff)lata wrote:Hi
I've also been experiencing a second error where discs are not properly burned and when played, during playback - at a point where two .vob meet, it sends the disc back to the menu. This is odd to say the least. This started a few months later.
I am still wondering if somehow I ended up with a defective/Bad install discs.
MysticNitekatt
- ram: 4GB
I've been holding off on trying either till I figure out if it's a computer issue or a software issue.BrianCee wrote:Since Corel no longer consider X4 as a supported product one thing for certain is that there will not be a patch or update to fix your problem now.
Hang on a minute, I see some tubleweeds going by
This may have been asked earlier, sorry if that is the case.
After setting the disc burner module…If you remove the disc from the drive the panel shows as Disc Type :- Disc empty
Is the option to Test Before burning available?
I see the option available………….
MysticNitekatt
- ram: 4GB
I don't think anyone has asked this question.lata wrote:Hi
Yes, it still is. The option is always selectable - with or without a disc in the burner.
I also have all 3 patches installed.
Now I am a little confused by your reply.
Are you saying that you can put a tick in the box marked "Test before Burning"
MysticNitekatt
- ram: 4GB
Yes, that is correct - the option to "tick"/"checkmark" the box for "Test Before Burning" is there both with and without a disc in the burner.
So, what does this mean?
MysticNitekatt
- ram: 4GB
So, does this determine something wrong?
I have been taking a short break and have not had internet access so apologise for the delay in my reply.
I am more confused, your title to this post “Re: STILL "Test Before Burning" Not Working in X4 Pro Update”
Indicates that this option is not working or available for you, yet now you state that the option is available and you can insert a "tick"/"checkmark" the box for "Test Before Burning"
So what makes you say the option is not working?
Maybe I have misunderstood the problem from the start as I assumed the option was not available for you ?????
MysticNitekatt
- ram: 4GB
Welcome back.lata wrote:Hi
The option is still listed on the control panel with or without a disc in the burner, and when it IS "tick"/"checkmark" it still doesn't run the test before burning, it just goes right into burning. So when it is selected to test before burning, it does not!
When you say it goes right into the burning - that's not true is it ? - before the burn starts the programme carries out a lot of conversions and multiplexing - what makes you think that the test is not in amongst them - what are you expecting to happen ?
In the back of my mind I have a recollection of a similar discussion many years ago and it was decided then that this 'test before burning' is an internal check on the file about to be burnt and that nothing was visible to the user at that time - just a system test to make sure all the 1's and 0's were in the right place.
MysticNitekatt
- ram: 4GB
Yes, I meant AFTER the pre-burn functions.
That is incorrect, "test before burning" is a visible,real time function taking the same amount of time the actual burning takes place. I had previous versions VideoStudio and that is how the worked. So if it takes 20 minutes for a disc with testing, the direct burn would be around 10 or so. Shows up on the status bar and everything.
MysticNitekatt
- ram: 4GB
Still trying to get to the bottom of this problem.
Two years this week and still no solution from Corel!
