Capture Problem
Coral
motherboard: Asus P8P67 Pro Rev. 3
processor: Intel Core i5 2400 Quad Core 3.1GHz Socket 1155
ram: 8 GB
Video Card: Gainward GT 520 1024 MB RAM
sound_card: On Board
Hard_Drive_Capacity: 500 GB X2
Monitor/Display Make & Model: AOC 19 inch CRT tube
Capture Problem
Post by Coral »
What's wrong here ? No driver found. I can capture with other applications without problems. Including Video Studio.
Re: Capture Problem
Hi Coral
Before asking questions in this forum Please Read This, it gives a guide as to the information required
You are not giving enough information other than you are using DVD Movie Factory and i assume the full version not the one provided with X3.
It would help if we knew what type of capture device you are using, I assume Firewire IEEE.
Some connections can only be accessed by one program at a time, so if you have another video capture program running that may be taking control of the port.
I know if i run Win DV, then try to capture with Corel software i get the same error and visa versa.
Coral
ram: 8 GB
Re: Capture Problem
Post by Coral »
Thank you for your reply. It is not the one provided with X3. I have used it on 2 analog capture (Yellow, White, Red RCA plugs) cards. ATI All-In-Wonder. Radeon 9600 and Compro C-500. Has not worked on both. I am aware that it is not possible to run two capture programms simultaneously.
skier-hughes
Microsoft MVP
motherboard: gigabyte
ram: 4GB
sound_card: onboard
Hard_Drive_Capacity: 36GB 2TB
Re: Capture Problem
Post by skier-hughes »
I've not tried to use movie factory to capture analogue sources, I'm not sure it will. I think it si just for digital (firewire) capture.
The general consensus is to use the programme that came with the capture card to capture then import into the programme you want to use.
Coral
ram: 8 GB
Re: Capture Problem
Post by Coral »
Graham,
Thank you for your reply. My hardware came with DVD Movie Factory 5 and Video Studio 11 SE. I find it strange that a more recent version of Movie Factory will not work. I have read in the Help information which mentions anolog capture cards.
