importing 3d model but can't add color or texture
benoit-1842
ram: 8gb
Video Card: radeon quad core
Hard_Drive_Capacity: 1tera
Monitor/Display Make & Model: hp
Post by benoit-1842 »
I have 3d models that I import but I can rotate them, scale them etc. but the color and texture doesn't show up.... Is there a way to change color or texture of my imported object or they have to stay gray ?
Thanx Ben
Re: importing 3d model but can't add color or texture
Hi Ben
You have to select the object from the Object Manager panel, expand the Group to identify the individual objects.
Once selected they should show with a red bounding box.
If you do not see the panels choose the left top menu View -- Palette Manager
Now the Colour option from Attributes Panel should be available.
kenneithharris
operating_system: Windows 7 Starter
motherboard: Intel
processor: Dual Core
ram: 2GB
Video Card: NVIDIA
sound_card: ASUS sound card
Hard_Drive_Capacity: 350Gb
Post by kenneithharris »
I want to advise you here that you can use any of software which helps you to fix this programme accurately. I also recommend you that Corel Draw might be help you for this to add colour and textures very easily. Actually, this idea is optional otherwise you can also import color or texture in 3D model via Palette Manager.
protto
Post by protto »
In my case the colour option in the Attributes Panel is not available even after selection...
Kingston
motherboard: Gateway [Acer] DX4860
processor: Intel Core i5 3rd gen. 3 GHz
ram: 8 GB
Video Card: Intel HD 2500
sound_card: Bluetooth
Hard_Drive_Capacity: 1 TB
Monitor/Display Make & Model: Dell ST2210; Samsung SmartTV 3D 40"
Post by Kingston »
When you open your 3D model, you can choose to open it as a C3D or as a D3D type. Those options are on the Open dialog where you choose your file to import.
You will have more attributes when you select to open your model as a D3D type.
See if that helps.
zaphodikus
motherboard: ROG-X570-F-Asus
processor: AMD 3950 - 16 core
ram: 64Gb
Video Card: AMD RX 6700
Hard_Drive_Capacity: M2 1TB
Monitor/Display Make & Model: 4K BenQ
Corel programs: VS 2023 Ultimate, Painter 2020
Post by zaphodikus »
Same issue.
This happens when selecting a group of objects. you have to expand the group and change the colour (or texture) of each element. Some properties are not available when a group has been selected - which is a pity that support for bulk or multi-select is not there in some of other form.
I'm sure there is a way to do this, it's just eluding me right now. For example when I import the 3D model for the aeroplane (biplane) it is orange - how do I go about changing it's colour?
zaphodikus
ram: 64Gb
Kingston has the answer. :D :D :D
1. Save the grouping as a directX .X file
2. Clear/delete object from the project
3. Import the file you saved in step 1 :) now you can change it's color - but remember that it's all one object now.
(Love it when I answer my own dumb question after hijacking/necroing someones thread.) :oops:
From the timeline list you can select individual object from the Group
Then change their Attributes / colours.
You do not have the required permissions to view the files attached to this post.
