Lens calibration data from LensFun/PTLens
beneix
processor: Intel Core i5-3337U
ram: 6GB
Video Card: GeForce GT 710M
Corel programs: ASP3
Post by beneix »
I have the Tamron 17-50 1:2.8 XR DiII, which seems to be not calibrated in the ASP database. Before embarking on learning about Linux/Cygwin, Hugin and afx's scripts, I did some browsing on the internet and found that LensFun has a lens profile in its database that looks like this:
- <lens>
<maker>Tamron</maker>
<model>Tamron 17-50mm f/2.8 XR Di II LD</model>
<mount>Canon EF</mount>
<mount>Nikon F AF</mount>
<mount>Pentax KAF</mount>
<mount>Sony Alpha</mount>
<cropfactor>1.5</cropfactor>
- <calibration>
<distortion model="ptlens" focal="17" a="0.02667" b="-0.07161" c="0.02012" />
<distortion model="ptlens" focal="24" a="0.02791" b="-0.08057" c="0.07132" />
<distortion model="ptlens" focal="35" a="-0.01098" b="0.0448" c="-0.04755" />
<distortion model="ptlens" focal="50" a="-0.00372" b="0.01796" c="-0.01334" />
<tca model="poly3" focal="17" br="0.0000205" vr="1.0005975" bb="-0.0001325" vb="1.0008428" />
<tca model="poly3" focal="24" br="-0.0000073" vr="1.0004585" bb="-0.0000382" vb="1.0004269" />
<tca model="poly3" focal="35" br="-0.0000351" vr="1.0002419" bb="-0.0000228" vb="1.0001575" />
<tca model="poly3" focal="50" br="-0.0000294" vr="1.0000100" bb="-0.0000149" vb="0.9999915" />
</calibration>
</lens>
Would it be possible to translate this data into an ASP profile, thus avoiding the schlepp of creating it from scratch?
ASP3 | Intel i5-3337U | GeForce 710M | 6GB RAM
afx
operating_system: Linux
System_Drive: N/A
Video Card: FirePro 4900
Re: Lens calibration data from LensFun/PTLens
Post by afx »
Everything is needed is there..
Code: Select all
begin lens
group: genericSLR
multiplier: 1.5
aperture: 2.8
menu_lens: Tamron 17-50mm f/2.8 XR Di II LD
cal_abc:  17 0.02667 -0.07161 0.02012
cal_abc:  24 0.02791 -0.08057 0.07132
cal_abc:  35 -0.01098 0.0448 -0.04755
cal_abc:  50 -0.00372 0.01796 -0.01334
end
Just use the ptlens parameters, the tca_model are not usable.
cheers
afx
beneix
ram: 6GB
Post by beneix »
Vielen Dank, afx -- I will have a try and see how this works, even if the focal lengths might be a bit too far apart (as per Colleen).
