X4 Ult doesn't launch cmdnongraphic.dll error
alanwin
motherboard: Aopen AX4SPE MaxII
processor: Pentium 4 3.2GHz
ram: 3GB
Video Card: GF 6200 512MB
sound_card: Realtek
Hard_Drive_Capacity: 1TB
Post by alanwin »
I installed X4 Ultimate onto a freshly reformatted XP SP3 machine and have severe problems trying to launch it - if I'm lucky it will run until I access (notably) some Help menu items or Check for Updates. Then it crashes with a reference to cmdnongraphic.dll Thereafter it will only run if I reset the workspace to default on start-up. Otherwise it doesn't start at all and the taskbar button briefly appears before vanishing. Even after I applied the Corel SP2 update manually I have the same problem. I can run it on a near identical-spec PC under Windows 7 Pro without a problem. Has anyone else seen this problem or a reference to this dll?
Thanks!
teknisyan
processor: Intel Corel i5
ram: 4 GB
sound_card: Realtek HD Audio
Hard_Drive_Capacity: 500 GB
Re: X4 Ult doesn't launch cmdnongraphic.dll error
Post by teknisyan »
Have you tried updating your DirectX?
If not, you download the latest version using the link for your Windows version.
Direct X: http://on-msn.com/aLrk0j (WinXP)
Direct X: http://www.microsoft.com/Windows/window ... tx-11.aspx
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
alanwin
ram: 3GB
sound_card: Realtek
Post by alanwin »
Thanks for the suggestion. Direct X is up to date (9.0c -- XP), I updated to the latest NVidia driver too but still have the same issue. I de-installed and cleaned up using Revo Uninstaller http://www.revouninstaller.com/ several times. I previously has PSP X so I re-installed and de-installed that cleanly as well. Have tried everything really!
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Post by hartpaul »
ave you done a google search on that dll. I checked quickly and found this which may help.
http://www.pcerrorfixtip.com/CmdNonGrap ... 89077.html
alanwin
ram: 3GB
sound_card: Realtek
Post by alanwin »
I'm afraid websites like those are designed just to sell a scareware scanning program. I couldn't find any hard-core resources on the web. It's a display-related dll so I tried all sorts of video card driver and monitor settings to no avail. Direct X, .NET 4.x , C++ 2005, 2008 are all installed and up to date too. :(
hartpaul
ram: 8 Gb
Post by hartpaul »
If you looked further down that page past the advertising there was a step by step procedure starting with :
How to Fix CmdNonGraphic.dll Error Efficiently?
You can follow the solutions to fix CmdNonGraphic.dll error completely:
Method One: Reinstall associated program with Windows built- in uninstall tool.
For Windows XP:
1.Click Start, go to Control Panel, and then double click to run Add or Remove Programs.
Further down there were instructions for Vista and Windows 7.
and
A.Directly Edit Windows Registry
1.Enable Registry Editor by clicking Start. And then typing "regedit" in the pop- up, press Enter.
alanwin
ram: 3GB
sound_card: Realtek
Post by alanwin »
Thanks for the pointer -- though I reinstalled the program 4 times and ensured everything was totally cleaned out of the registry. Guess I hit a brick wall. Never had any such problem before, going back to Jasc PSP 3 on Win 3.1.
yyeefix
operating_system: Windows 7 Starter
Post by yyeefix »
if have you tried updating your DirectX, it maybe a CmdNonGraphic.dll error and you must fix this error. Read article do it: http://www.fixpctool.com/datapage/how-t ... error.html
alanwin
ram: 3GB
sound_card: Realtek
Post by alanwin »
Nah. I'd never dream of downloading any registry fix/ cleaner/ uninstaller tool from an untrusted and suspicious-looking non-authentic source. The web is full of them.
Corel says it's related to display drivers, and the error is almost certainly caused by a conflict with a service or process, but which one...
Simone Corel UK
Alludo
Post by Simone Corel UK »
Hi to all with that error
This error is related to very old computers with AMD Athlon processors. They are missing SSE http://en.wikipedia.org/wiki/Streaming_SIMD_Extensions, when AMD produced these processors. There is no way to get PSPX4 running on these old machines.
This affects 8 years old machines and I would suggest that you buy a new one until October or wait for Windows 8. You can still make a decision what OS you want. :!:
alanwin
ram: 3GB
sound_card: Realtek
Post by alanwin »
Sorry to disappoint but it's not AMD it's an Intel Pentium4 processor. Furthermore my PCs exceed the System Requirements advertised on the packaging.
XP with the latest service packs (yes SP3)
1.5GHZ (3.2GHz)
1GB RAM (3GB)
1GB of free harddisk space (692GB free)
1024 x 768 display (yes)
I reverted to Paint Shop Pro X instead, which is not what I call progress.
On my near-identical Windows 7 machine, I find that PSP Ult X4 locks up as soon as I access the images on a compact flash card. Tonight I gave up after having to constantly reboot it and I've gone over to my PSP X machine to get some simple graphics done.
All in all, I've never been as disappointed with any program recently as I have been with PSP Ult X4. It promised so much but actually I kind of wish I'd not bothered. If I switch to Windows 8 the whole conspiracy starts again, with dozens of programs that may or may not work so we'll be encouraged to 'upgrade'.
