Exporting EXIF Not Viewable Everywhere
klaxian
- System_Drive: N/A
- motherboard: ASUS P67 Revolution
- processor: Intel 3770k 4.6GHz
- Video Card: Nvidia GTX 480 SLI
- Hard_Drive_Capacity: 240GB SSD
- Monitor/Display Make & Model: 3 x ASUS ML248H
When exporting a JPG from ASP, the EXIF information contained within it is not readable by some other applications. For example, Google+ and Picasa can't read it. JPGs straight from the camera and files exported from ASP and subsequently edited with GIMP do not have this problem. Is ASP perhaps saving EXIF data in a non-standard format? Can this be fixed? Thanks.
afx
- System_Drive: N/A
- Video Card: FirePro 4900
Re: Exporting EXIF Not Viewable Everywhere
You might want to check this in detail with exiftool -g0 -D.
cheers
afx
cheers
afx
klaxian
- System_Drive: N/A
Thanks. I'm on Linux so exiftool isn't an option for me (or I couldn't find a Linux version). I installed exifprobe though and I'll investigate further.
afx
- System_Drive: N/A
Every Linux distro worth a penny has exiftool, check again
cheers
afx
cheers
afx
klaxian
- System_Drive: N/A
Found it. It's in the libimage-exiftool-perl package.
klaxian
- System_Drive: N/A
Well there does seem to be quite a difference between EXIF information in a file saved from ASP and a JPG straight from the camera. At first glance, there is 3x as much data in the camera JPG. Why is ASP stripping so much from the EXIF when saving? I suspect that the applications that don't show data from ASP JPGs (ie. Google Picasa) are looking for meta tags that ASP leaves out.
Here are examples:
JPG exported from ASP: http://pastebin.com/wkRkWqiC
JPG straight from the camera: http://pastebin.com/jTPPWuUL
Any thoughts on how to get full EXIFs from ASP exports?
Here are examples:
Look into "COPYING EXAMPLES" section of exiftool man.
ferdinand-paris
- motherboard: GA-X58A-UD3R
- processor: 3.20 gigahertz Intel Core i7 960
- ram: 4Gb
- Video Card: NVIDIA GeForce 7300 GS
- sound_card: Realtek High Definition Audio on-board
- Hard_Drive_Capacity: 2500 Gb
- Monitor/Display Make & Model: Eizo CG222W
The simple answer is that camera makers put a lot of the metadata in an encoded form in the "EXIF maker notes", and these are not documented by any camera maker that I know of. So software writers have to work these out for themselves for each camera (and lens). Bibble 4 used to be able to output the maker notes for some Nikons, but that wasn't transferred across to Bibble 5 or Aftershot Pro. So the JPG from the camera will have the maker notes but the developed RAW won't. I suspect that ASP is not alone in this behaviour.
As another example of this issue, many of the Sony and Sigma lenses for my NEX-7 need lens corrections applied. I've worked out the (a,b,c) parameters for each of these lenses and put them into the Aftershot Pro lens DB. But ASP doesn't recognise the lens, presumably because it's encoded in the maker notes. So if I have an image taken at 30mm focal length, was this the Sigma 30mm, or the 18-55 set at 30mm? I need to know which lens was used in order to apply the right correction.
As noted, ExifTool is the answer. You can use it to copy the maker notes from the RAW to the JPG. As it's a command line program it's not easy to use. Windows users can use iMatch and a script I wrote to automate the process.
F_P
F_P
Dutchmm
- System_Drive: N/A
- motherboard: Asus 97
- processor: Intel i7 4785T
- Video Card: Onboard Intel
- sound_card: Intel AC97
- Hard_Drive_Capacity: 2.5TB
- Monitor/Display Make & Model: Philips 28"
- Corel programs: ASP 3 Pro (and 2 and 1 before)
Ferdinand
Did you write the iMatch script to which you refer because you couldn't find a decent scripting language on Windows?
I am trying to help Sebastian on the Facebook page to retain some of the GPS settings that (despite their being official EXIF tags) AS doesn't load from the original. I know how to script for this on Linux, but I haven't used Windows for some time now (and I'm not boasting).
It looks, on first examination, as though it would be possible to write a Powershell script to execute exiftool and manipulate the path variables necessary in order to re-connect the EXIF info from the raw to the output?
Regards
Regards
ferdinand-paris
- ram: 4Gb
Yes, I wrote the script, over many years. You can get it here. To run it you need iMatch, which is a DAM program. iMatch comes with WinWrap Basis, which is a flavour of VB basic, so that's what the script is run in.
IIRC you can run ExiTool batch jobs from the command line, if your files are named and located "correctly". So I think you can copy EXIF from all files in a folder named like DSCxxxx.NEF to files named DSCxxxx.JPG in the same folder. The script makes it easier and gives you more control, but you need iMatch.
F_P
F_P
ferdinand-paris
- ram: 4Gb
In this ExifTool documentation page:
http://www.sno.phy.queensu.ca/~phil/exi ... l_pod.html
There is this copying example:
exiftool -tagsfromfile %d%f.CRW -r -ext JPG dir
- - -Recursively rewrite all JPG images in dir with information copied from the corresponding CRW images in the same directories.
You'd need to edit this command and specify just the tags you want copied, but it should work.
F_P
F_P
klaxian
- System_Drive: N/A
Thanks. I am aware there are workarounds. However, this issue shouldn't exist in the first place. If I can copy the remaining EXIF data to any exported JPGs, ASP should be able to do the same thing without an additional step. I already have to edit my images because of the 1px edge line bugs. I am using ASP to streamline my workflow, not to add more steps to it. I hope the software is improved to address this.
EOS
- System_Drive: N/A
- motherboard: Gigabyte
- processor: Core i7-3930K
- ram: 12GB
- Monitor/Display Make & Model: 2x Samsung SyncMaster 21 inch
idd, this should be not existsklaxian wrote:However, this issue shouldn't exist in the first place. .
me have problems with the exif comment......
Code: Select all
9: Exif Byte Order : Big-endian (Motorola, MM)Bibble since 2004. Aftershot until 2020. From then on darktable.
klaxian
- System_Drive: N/A
I don't think the problem is Google not supporting Big-endian because a small amount of the EXIF data is displayed (ie. camera and model). I suspect they are looking for exposure, aperture, and others in tags that are not exported by ASP. These are found in exports from other applications like LightRoom and GIMP though.
The main problem is that ASP seems to strip lots of tags on export and the ones it saves are not the same as what some other (popular) applications expect.
The other thing I noticed is that this problem is much worse when dealing with RAW files than JPGs from the camera. Tons of EXIF tags are omitted or changed when exporting RAW to JPG, but exports after starting with a JPG carry though most if not all of the tags in a usable way.
Am I really crazy for thinking this is a problem?
