Burning DVDs
Burning DVDs
I am trying to publish several videos to one DVD. I used the menu template and everything works fine after burning the DVD. The DVD auto plays and shows the main menu. The previews are fine. When I click a video to start, it looks good.However, I cannot find a way to easily return to the main menu so I can start the next video. I tried adding navigation buttons but when I previewed the DVD, they did not work. Am I missing something?
Re: Burning DVDs
Yes you are missing a setting in the 'Create disc' window
After you click on Create disc and the new window opens look to the bottom left corner of it where you will see a number of icons - click on the one which looks like a little gear wheel - when the new dialogue box opens look towards the bottom of it. Click to uncheck the "Auto repeat when disc playback ends" option and then change the little drop down under it to "Back to menu" - click the "OK" at the top of that dialogue box and continue as before - discs burned after that should do what you want.
Re: Burning DVDs
You are wonderful. Thanks for the help!
