Mini DV not recognize...
tousabloc
motherboard: Intel DP67BG B3
processor: Intel Sandybridge Core i5 2500K
ram: 8Gb
Video Card: MSI GTS 450 1Go GDDR5 OC
sound_card: Integrated
Hard_Drive_Capacity: 1To
Monitor/Display Make & Model: SAMSUNG SyncMaster P2370
Post by tousabloc »
hello, i have 1 camcorder in firewire 1394 MiniDV to record in my computer.
The drivers is ok, the camcorder function well on other pc with corel x4 or pinnacle, but on the pc with x5 ultimate, when i want to make capture i have message error "not connecting or no drivers..."
can you help me, i must record video on pc !
thanks
Re: Mini DV not recognize...
Windows 7 updates have introduced a new Firewire driver which cannot be used by Video Studio. You need to go into Control Panel > Device Manager, and select IEEE1394. Right click it and select Properties, then the Driver tab on the dialogue box which appears. Select 'Roll back driver' and click the downward pointing arrow. There should be something like OHCI legacy driver. Select that and click OK. (I'm sorry I can't be more accurate about the language, but I am currently using an Android tablet and so do not have VS or Windows in front of me...)
You could also as an alternative do what a lot of us here do, and that is use a small freeware program called WinDV to capture with. You can find it at windv.mourek.cz
tousabloc
ram: 8Gb
Post by tousabloc »
thanks for your answer.
I have tried the 3 drivers compatibles by windows, but nothing change.
Where can i find the good IEEE Driver for W7 Premium 64 bits ?
HELP PLEASE...
Post by BrianCee »
but did you do as Ken suggested and use the LEGACY driver - no other drivers work with Win 7 and X5
tousabloc
ram: 8Gb
Post by tousabloc »
hello
they don't work
HELP PLEASE
Well, have you tried using, as I suggested, WinDV? If that doesn't work as well, then it is a problem with your system and not with the individual programs like Video Studio...
tousabloc
ram: 8Gb
Post by tousabloc »
HELLO
IN WINDV it is write no media...
i have test in pinnacle hd 15, same problem.
I have connect cable ieee 1394 to my mother board intel dp67bg... i have no driver found for it !!!
I've now opened one of my computers which has a firewire connection and uses Windows 7. One other thing you can try is as follows:
1- Open Device Manager
2- Expand the "IEEE 1394 Bus Host Controllers" node in the device tree by double clicking.
3- Select the Driver tab and the click the Update driver button.
4- Select "Browse my computer for driver software"
5- Select "let me pick from a list of device drivers on my computer ..." and Check the box before “Show compatible hardware”.
6. Choose the second option--- "1394 OHCI Compliant Host Controller (Legacy)", and click next to update the driver.
tousabloc
ram: 8Gb
Post by tousabloc »
hello,
thanks for your help.
i have tried all this, but not work.
I have motherboard Intel DP67BG and camcorder JVC GR-D21E
The plugin is IEEE1394 is installed but he don't see the camcorder.
My card has the IEEE1394 version 'a' ... i have not found intel driver specificaly.
skier-hughes
Microsoft MVP
motherboard: gigabyte
ram: 4GB
sound_card: onboard
Hard_Drive_Capacity: 36GB 2TB
Post by skier-hughes »
If three programmes don't work adn you have a driver installed it sounds like you have a hardware problem, either the cable or one of hte firewire ports on cam/pc is broken.
Find a pc/cable/cam that works and test your items with these to find out what is faulty.
How many drivers do you see when you view the Device Manager IEE1394 Bus.....
Un-install all all except the 1394 OHCI Compliant Host Controller
Right click the 1394 OHCI Compliant Host Controller and select "Scan for Hardware Changes"
I have just carries out this operation, a new driver was installed that allowed me to capture, by the way i am using XP.
barbarak
motherboard: intel
processor: amd
ram: 3 gb
Monitor/Display Make & Model: hp
Post by barbarak »
see no HDV record
I don’t understand your reference to "see no HDV record "
There is another poster with a similar problem,
The first image shows the Device Manager with reference to the IEEE 1394 and Imaging Devices showing the camera......
What do you see when viewing your device manager?
http://forum.corel.com/EN/viewtopic.php ... 71#p251771
Post by BrianCee »
I think barbarak wants you to look at this topic Trevor ;- http://forum.corel.com/EN/viewtopic.php?f=1&t=47117
Hi sorry
I assumed the post was from tousabloc, the original poster.
I also assume tousabloc is not using HD but standard Mini-DV
