AfterShot crash after start - core dump
Bugs & Suggestions
ptr
operating_system: Linux
System_Drive: N/A
Post by ptr »
Hello, I've got serious problem with AfterShot it crashes just after start. I've tried:
- AfterShot reinstalation
- clearing settings and catalog folders
Any suggestions? Thanks for help
Log file:
Code: Select all
Install Path:           /opt/AfterShotPro
LD_PATH:                /opt/AfterShotPro/lib:
XLIB_SKIP_ARGB_VISUALS: 1
70221.608: I have SSE2
70221.611: Bibble program arguments ("./AfterShotPro")
70221.612: Loaded  "/opt/AfterShotPro/supportfiles/locale/aftershot_en.qm"
70221.612: Loading plugins
70221.617: System locale: pl_PL
70221.618: Loaded  "/opt/AfterShotPro/supportfiles/locale/aftershot_en.qm"
70221.667: AfterShot vers.: 1.0.0.39
70221.667: Built on: "wt. gru 27 2011"
70221.667: Language: en
70221.667: App Path: /opt/AfterShotPro/bin/AfterShotPro
70221.667: System Home: ../supportfiles
70221.667: User Home: /home/peter07/.AfterShotPro
70221.667: Prefs Home: /home/peter07/.config/Corel/AfterShot Pro.conf
70221.668: Platform:     Linux
70221.668: Issue: "Ubuntu 12.04 LTS \n \l"
70221.668: Kernel: "Linux version 3.2.0-26-generic (buildd@lamiak) (gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) ) #41-Ubuntu SMP Thu Jun 14 16:26:01 UTC 2012"
70221.668: Build Mode:   Release
70221.668: Product Name: "AfterShot Pro"
70221.668: Registered Version
70221.669: Initializing
70221.669: Cpu Manager init: 2
70221.669: "MemTotal:        3093260 kB"
70221.669: Memory:  2.94996
70221.669: ====================================================
70221.669: Asset: 2147483647 purge
70221.670: ====================================================
70221.670: Heavy Asset: 2147483647 purge
70221.670: NoiseEngine: 147 purge
70221.670: NoiseEngine: 73 cache (50 min)
70221.670: Histogram: 23 purge
70221.670: Histogram: 12 cache (12 min)
70221.670: PluginData: 8 purge
70221.670: PluginData: 8 cache (8 min)
70221.670: ImageMaster: 589 purge
70221.670: ImageMaster: 294 cache (50 min)
70221.670: NContainer: 2147483647 purge
70221.671: Path: 2147483647 purge
70221.671: Path: 2147483647 cache (2147483647 min)
70221.671: ====================================================
70221.671: RawData: 24746077 purge
70221.671: UncompressedRawData: 8 purge
70221.671: UncompressedRawData: 8 cache (8 min)
70221.671: Version: 589 purge
70221.671: Version: 294 cache (50 min)
70221.671: PerfectlyClear: 5 purge
70221.671: PerfectlyClear: 4 cache (4 min)
70221.671: TileStack: 23 purge
70221.671: TileStack: 12 cache (12 min)
70221.672: StackTile: 2949 purge
tcmalloc: large alloc 1358245888 bytes == 0x66813000 @
70221.688: ====================================================
70221.688: BImageTile: 1769 purge
70221.688: BTiledImage: 2147483647 purge
70221.688: RegionImageTile: 2949 purge
70221.689: ====================================================
70221.689: Allocate Asset manager
70221.690: Option group -  ""  - already contains an option with name -  "TIFFTAG_AFMODE"
70221.690:   Option was not registered.
70221.690: Option group -  ""  - already contains an option with name -  "TIFFTAG_FLASHMODE"
70221.691: Globals: systemhome ../supportfiles
70221.691: Globals: userhome /home/peter07/.AfterShotPro
70221.691:
====================  Plugins  =====================
      Name:
Identifier:
   Version: 1.0.0
      Path:
      Name: Black and White
Identifier: com.corel.BlackAndWhite
   Version: 1.0.0
      Path: <System Home>/plugins/Black and White.afplugin
Naruszenie ochrony pamięci (core dumped)
SteveCase
System_Drive: N/A
motherboard: ASRock 990FX Extreme4
processor: AMD FX-8350
ram: 16.0 GB
Video Card: GTX 550ti
Re: AfterShot crash after start - core dump
Post by SteveCase »
Steve in Seattle,WA
afx
System_Drive: N/A
Video Card: FirePro 4900
Post by afx »
You might want to start it in a terminal. That could give you more error messages.
strace -ff -o /tmp/as.log /usr/bin/AfterShotpro might be be helpful.
I suspect a broken plugin. Did you remove/rename your plugin folder for a test yet? If not, try this first.
cheers
afx
kaymann
motherboard: ASUS P8P67 PRO REV 3.1
processor: Intel i-7 6800K
ram: 32 GB
Video Card: NVidia GeForce RTX 2060
sound_card: Onboard
Hard_Drive_Capacity: 3.5 T
Monitor/Display Make & Model: MSI MAG 341CQ & Dell 2470
Corel programs: PSP 2019 Ult, Painter 2020, CorelDraw X7
Post by kaymann »
Is version 1.0.0.39 the latest for linux. I thought we had 1.0.1.10 for Linux...
ptr
System_Drive: N/A
Post by ptr »
Ok, I've just updated AfterShot to newest version: AfterShot vers.: 1.0.1.10, and I've also deleted AfterShot home directory (and DB too) - so I've got only basic plugins. Application still crashes, strace log: http://www.nopaste.pl/1dr7.
//Edit
More information after core dump analyze:
Disassembly (made by Ubuntu apport):
Code: Select all
=> 0x2bf416 <__kernel_vsyscall+2>:	ret
   0x2bf417:	add    %ch,(%esi)
   0x2bf419:	jae    0x2bf483
   0x2bf41b:	jae    0x2bf491
   0x2bf41d:	jb     0x2bf493
   0x2bf41f:	popa
   0x2bf420:	bound  %eax,(%eax)
   0x2bf422:	cs
   0x2bf423:	push   $0x687361
   0x2bf428:	cs
   0x2bf429:	fs
   0x2bf42a:	jns    0x2bf49a
   0x2bf42c:	jae    0x2bf4a7
   0x2bf42e:	insl   (%dx),%es:(%edi)
   0x2bf42f:	add    %ch,(%esi)
   0x2bf431:	fs
Gdb output:
Code: Select all
Core was generated by `strace -ff -o /tmp/as.log AfterShotPro'.
Program terminated with signal 11, Segmentation fault.
#0  0x002bf416 in __kernel_vsyscall ()
//Edit
Case closed, ~/.config/Corel/AfterShot Pro.conf was broken. After recreating - everything starts to working. Thanks for suggestions
