So, I have a great lens profile for the 20-50 Samsung NX Lens but having looked around, there's nowhere for me to put it. No configuration file?
So, yeah... help!
Samsung NX100 Lens Profile - Um... where does it go?
afx
- System_Drive: N/A
- Video Card: FirePro 4900
Re: Samsung NX100 Lens Profile - Um... where does it go?
Look in %ProgramFiles% \Corel\Corel AfterShot Pro\supportfiles\Profiles\LensProfiles
cheers
afx
cheers
afx
what file though? i've been through them all and there's none there for samsung lenses - that is, no 'lens table' file for samsung lenses at all. could you help with that?
Hobgoblin
- System_Drive: N/A
Possibly - 'profile_genericSLR.txt' that you need to look in.kye wrote:what file though? i've been through them all and there's none there for samsung lenses - that is, no 'lens table' file for samsung lenses at all. could you help with that?
R.
greerd
- System_Drive: Z
- processor: Intel i7 920
- ram: 12 GiB
- Video Card: nVidia GeForce 260
- sound_card: Onboard
- Hard_Drive_Capacity: 5 TB
- Monitor/Display Make & Model: Dell UltraSharp U2410
Looks to me like the NX100 is listed in the 'profile_samsungSLR.txt' file. The group listed for all NX cameras (available) is 'samsungNX', but since there is no 'profile_samsungNX.txt' file, no profiles exist for your camera. If you have your own profiles, I think that you could just create the missing file 'profile_samsungNX.txt' in the same directory and put in your profiles.Hobgoblin wrote:Possibly - 'profile_genericSLR.txt' that you need to look in.kye wrote:what file though? i've been through them all and there's none there for samsung lenses - that is, no 'lens table' file for samsung lenses at all. could you help with that?
R.
NOTE: your 'profile_samsungNX.txt' will most likely be overwritten or deleted during the next ASP update.
Dutchmm
- System_Drive: N/A
- motherboard: Asus 97
- processor: Intel i7 4785T
- Video Card: Onboard Intel
- sound_card: Intel AC97
- Hard_Drive_Capacity: 2.5TB
- Monitor/Display Make & Model: Philips 28"
- Corel programs: ASP 3 Pro (and 2 and 1 before)
In a linux box, the file to which you add your calibration data is /opt/AfterShotPro/supportfiles/Profiles/LensProfiles/profile_samsungSLR.txt
As I understand it, this is likely to map to [pick a drive]:\Program Files\Corel\AfterShotPro\supportfiles\Profiles\LensProfiles\profile_samsungSLR.txt on Windoze.
The NX100 has already got a slot for you to add your calibration data there.
As the previous poster remarks, keep a copy to restore after your next upgrade of AS.
HTH
Mike
HTH
Mike
