Hello everyone, typically, here I am in the middle of creating a new film which is required at the end of the week and the dreaded error box appeared today, "No storage to load BB"! This was while loading into a Library folder. I closed the error and continued. All seems to have loaded in correctly and I have utilised these links in the film this afternoon. I am using ProX3 by the way with latest updates. I have plenty of space on my hard-drive if that has anything to do with it. I know this was raised a couple of years ago by another board members. Are we any further forward on solution? I am fearful of getting involved in too much at the moment as i urgently require the suite to finish my film! I have backed up twice over just in case but it has made me nervous. I hope all goes well when I come to create the video file and burn etc. Any comments welcome. Thanks
Nick (Viddynick)
Error box
canuck
Re: Error box
You will have to supply a lot more information on what you are doing when you get that error message.
Are you trying to load something from a Blackberry? A video file, photo or what?
Re: Error box
Trevor Andrew appears to have finally cracked this mystery in February: http://forum.corel.com/EN/viewtopic.php ... 44#p240344
Re: Error box
Hi all, thanks for your responses. Basically, the error appeared when I was loading video files into the Library via the VS link, load files to library. I had created a library folder for this previously already had some stuff in it. I have quite a lot of folders in the library for all the different subject matter I'm working on. The video files were stored in the Pictures folder on C Drive. By the way I have more than 50% of space on that drive, so it can't be that. I am reluctant to try to fix when I have an important film in progress and can't afford a reinstall! - but I will check out Trevor's postings when I am free. In the meantime, I am hoping all will be well - all seems quiet at the moment! Thank you again for your help as always. One day I hope to be of some use to some of you! Cheers,
Nick (Viddynick).
Nick (Viddynick).
