How to lower exposure of just my selection
Jakespeare
- motherboard: Asus M3N-HT Deluxe
- processor: AMD Phenom X4 9950 Black Edition
- Video Card: NVIDIA Geforce GTX 280
- sound_card: Onboard
- Hard_Drive_Capacity: 2TB
- Monitor/Display Make & Model: Viewsonic VX2835wm
I have several raw photos, and when my exposure has been brought to -2 the glare of the flash on skin is much warmer and acceptable. However, the rest of the photo is not. What is a good practice for reducing exposure for just my selection of the photo?
Joelle
- motherboard: Asus Prime B350M-A
- processor: AMD Ryzen 5 1500 Quad-Core
- ram: 16 GB RAM
- Video Card: NVidia GeForce GTX 1050
- Hard_Drive_Capacity: 1TB
- Monitor/Display Make & Model: Samsung
- Corel programs: PaintShop Pro X9
Re: How to lower exposure of just my selection
It's a bit hard to work out what is amiss with your photo if we can't see the photo.Jakespeare wrote:I have several raw photos, and when my exposure has been brought to -2 the glare of the flash on skin is much warmer and acceptable. However, the rest of the photo is not. What is a good practice for reducing exposure for just my selection of the photo?
But as you can't adjust such things in a RAW image, you need to convert the image so you can work on it.
Using the Backlighting filter might help, or the Histogram, or the Curves Adjustment filter.
Joëlle
Joëlle
(PSPX9 )
(PSPX9 )
- hartpaul
- ram: 8 Gb
For flash burn on skin I would just process the image for the best skin tones for the majority of the person, then use clone tool set at say 20 opacity and slowly soften and replace the whited out flash hot spot. Have done it plenty of times and becomes quite easy to do. See my example below which has gone for the completely matte full makeup look, but you can allow a bit of the flash to stay for a more natural look.
Joelle
- ram: 16 GB RAM
With an image like yours my approach would be to select the shiny bits with some room to spare, promote those to new layer and fill them with the colour sampled from the surrounding are, deselect the selection and blur, then adjust the opacity.hartpaul wrote:For flash burn on skin I would just process the image for the best skin tones for the majority of the person, then use clone tool set at say 20 opacity and slowly soften and replace the whited out flash hot spot. Have done it plenty of times and becomes quite easy to do. See my example below which has gone for the completely matte full makeup look, but you can allow a bit of the flash to stay for a more natural look.
Which is likely what you did too
Joëlle
Joëlle
(PSPX9 )
(PSPX9 )
This is fairly easy actually, but it will sound more complicated in step-by-step text. Since you have a RAW file save one version as a JPEG at normal exposure levels, and a second version at -2.
Open both files normally. Pick the file with the smallest portion you want to use (assume its the -2 version for now, and all you want is the facial portion), and click on that image to select it as the active image. CTRL-A to select all, CTRL-C to copy, then click on the other (normal exposure) image to select it as the active image, and CTRL-V to paste as a second layer into that image. You can also do this with right-click commands as well as the CTRL keystrokes. You will now see a second layer in the layers palette, and if the second layer is selected as the active layer, the entire image will look like the -2 exposure image. then select Layers/new mask layer/hide all, you'll see a black mask box to the right in the layer icon, and now your image will look like the normal exposure image. Now select the brush tool, and paint white over where you want the -2 exposure image to be selected, you'll see it in place of the other image everywhere you paint white. to get a more gradual transition you can paint gray around the white areas, and you can adjust the opacity of all changes with the slider in the layers palette. You can also experiment with other blending modes, but for this application normal blending mode is probably as good as anything. If you paint too much white, just switch to black and paint out the excess white to get the normal exposure portions to reveal in the composite image.
