Priority of data for asGPS
AfterShot Pro Plugins
leahcimi
motherboard: Gigabyte Technology Co. Ltd. H61M-D2H-USB3
processor: 3.40 gigahertz Intel Core i7-2600K
Video Card: Intel HD Graphics 3000
sound_card: High Definition Audio Device
Hard_Drive_Capacity: 250GB 500G
Monitor/Display Make & Model: Acer S240HL
Post by leahcimi »
I use GeoSetter to geotag Canon RAW (CR2) images and have the option of writng the GPS data into the image file or a sidecar file.
The default is to write the data into a sidecar file which has the format 'imagefile.xmp'. This means that asGPS does not see the data and doesn't show a position on its map.
If I write the GPS data into the CR2 file, asGPS works fine provided I haven't already done some editing with AfterShot Pro; if I have, asGPS doesn't see the GPS data in the image file and seems to be overridden by empty fields in the 'imagefile.cr2.xmp' file created by AfterShot Pro.
I have discovered a workaround for this but it is a bit messy: if an image has had GPS data added to it after the creation of an AfterShot pro xmp file, first create a new version from default, then copy its properties (Ctrl-C) and paste then into the original, then delete the new version.
andreas
operating_system: Linux
System_Drive: X
motherboard: Asus in Workstation and Dell XPS Notebook
processor: i7-980 and i7-2720QM
ram: 12GB - 8GB
Video Card: ATI FireGL
sound_card: on board
Hard_Drive_Capacity: 4.5TB Rd10
Monitor/Display Make & Model: Samsung Syncmaster 2343sw
Re: Priority of data for asGPS
Post by andreas »
Hm,
I think "merge external metadata" in ASP (from menu) should merge the data from your xmp files. asGPS should see these values after that. asGPS does only see tags/options ASP is aware of. If it doesn't, please make a small test, write what you have done and provide the AfterShotPro.log file.
Andreas
Linux - not Windows
leahcimi
Post by leahcimi »
Thanks Andreas,
Indeed AfterShot Pro's "Merge External Matadata" does merge the data from the xmp files.
Thanks for your help.
