PluginTools: Plugin Configuration
AfterShot Pro Plugins
andreas
operating_system: Linux
System_Drive: X
motherboard: Asus in Workstation and Dell XPS Notebook
processor: i7-980 and i7-2720QM
ram: 12GB - 8GB
Video Card: ATI FireGL
sound_card: on board
Hard_Drive_Capacity: 4.5TB Rd10
Monitor/Display Make & Model: Samsung Syncmaster 2343sw
Post by andreas »
the plugin SDK offers the info for a directory for plugin relevant data, resp. configuration files and so on. With
Code: Select all
git clone http://schrell.de/PluginTools.git
You can get code for a configuration interface which can be used by your plugin. You have to create a field for the configuration and create a configuration mapper for interaction with your config. It creates or uses a directory named like your plugin and a config file in there also named like your plugin. Here is my implementation when using it in asPluginManager:
Code: Select all
#pragma once
#include <QString>
#include <QObject>
#include "ConfigFile.h"
#include "PluginHub.h"
#include "PluginDependency.h"
#include "PluginImageSettings.h"
#include "PluginOptionList.h"
#define ASPM_CHECK_FOR_UPDATES "ASPM_CHECK_FOR_UPDATES"
#define ASPM_TOOLBOX_HEIGHT "ASPM_TOOLBOX_HEIGHT"
class ConfigurationMapper : public QObject {
        Q_OBJECT
    public:
        ConfigurationMapper(QString filename);
        bool getBool(const QString key, bool def);
        QString getString(const QString key, QString def);
        int getInt(const QString key, int def);
        void setString(const QString key, const QString val);
        bool checkForUpdates();
        int toolBoxHeight();
private:
        ConfigFile *m_cf;
and
Code: Select all
#include "ConfigurationMapper.h"
#include <QDebug>
#include <QString>
#include <QStringList>
ConfigurationMapper::ConfigurationMapper(QString fileName) {
    m_cf = new ConfigFile(fileName);
    m_cf->autoWrite(true);
bool ConfigurationMapper::getBool(const QString key, bool def = false) {
    QString val = m_cf->getValue(key);
    if (val == 0) return def;
    return val == "true";
QString ConfigurationMapper::getString(const QString key, QString def = "") {
    return val;
int ConfigurationMapper::getInt(const QString key, int def = 0) {
    return val.toInt();
void ConfigurationMapper::setString(const QString key, const QString val) {
    m_cf->setValue(key, val);
bool ConfigurationMapper::checkForUpdates() {
    return getBool(ASPM_CHECK_FOR_UPDATES, true);
int ConfigurationMapper::toolBoxHeight() {
    return getInt(ASPM_TOOLBOX_HEIGHT, 400);
In your plugin code you have to initialize the configuration, after that you can read or set values. When setting values the config file is updated automatically.
Init:
Code: Select all
    QString configDir = m_hub->property("pluginStorageHome").toString() + "/asPluginManager";
    QDir qdir;
    qdir.mkdir(configDir);
    QString configPath = configDir + "/asPluginManager.conf";
    m_config = new ConfigurationMapper(configPath);
    if (m_config == NULL) {
        QMessageBox::information(NULL,"asPluginManager",tr("Configuration file problem with file:") + "<br/>" + configPath);
        return false;
usage in your code:
Code: Select all
if (m_config->checkForUpdates()) {
uiWidget->setMinimumSize(100, min(height, m_config->toolBoxHeight()));
What will change in the near future:
  • A ConfigurationMapperBase will preimplement the getter and setter methods. Your will extend it with your own methods
  • Integrated dir/path management
It is possible to use this method both for configuration based on an ui like asGPS does or with config file changes only with a text editor. Like it is implemented in asPluginManager at the moment.
Andreas
Linux - not Windows
