Sometimes after importing images into my catalog, I inadvertantly included a mix of jpgs & raw formats for every image. This means I have two thumbnails per original captured file when I review my shots.
I'd like to select all jpgs and move them to a new subfolder. I can't see a way to make that selection via a filter or search of some kind that selects based on filename extension (.jpg, .orw, .crw etc etc)...so I have to manually select using CTRL-Click on each jpg.
Is there a more efficient way?
Filter by filename in Catalog?
afx
- System_Drive: N/A
- Video Card: FirePro 4900
Re: Filter by filename in Catalog?
You can select file type / JPGs via the photo info in the metadata browser for imported images.
cheers
afx
cheers
afx
