When I select "Test Before Burning" it doesn't test, but goes straight to burning (I burn at 4.0 speed)
Also, while burning the detailed progress display continues to say "Video/Audio Multiplexing" through the entire process until closing the disc.
I've installed both current patches as well.
So what is wrong?
"Test Before Burning" Not Working in X4 Pro
MysticNitekatt
- motherboard: Dell Inc. 04GJJT
- processor: 3.10 gigahertz AMD Athlon II X4 645 Multi-core
- ram: 4GB
- sound_card: ATI High Definition Audio Device i
- Hard_Drive_Capacity: 1TB
- Monitor/Display Make & Model: DELL E157FP
"In Space, No One Can Here You MEOW!"
MysticNitekatt
- ram: 4GB
Re: "Test Before Burning" Not Working in X4 Pro
I tried a reinstall, problem still there.
Kingston
- motherboard: Gateway [Acer] DX4860
- processor: Intel Core i5 3rd gen. 3 GHz
- ram: 8 GB
- Video Card: Intel HD 2500
- sound_card: Bluetooth
- Hard_Drive_Capacity: 1 TB
- Monitor/Display Make & Model: Dell ST2210; Samsung SmartTV 3D 40"
Did it actually burn something on the disc?
It's suppose to simulate the actual rendering and burning of your project, but not actually burn anything on the disc. To me, that's a waste of time. You would be better off by burning the disc contents to a folder. Then you would know that the rendering succeeded and actually have something to show for it.
MysticNitekatt
- ram: 4GB
Yes, it burned the disc with no problem as far as I can tell.Kingston wrote:Did it actually burn something on the disc?
It just isn't testing before burning or showing proper status on the detailed progress display.
Been using Ulead/Corel software for years and prefer testing before burning feature.
canuck
I am in complete agreement with Kingston: testing before a burn is a total waste of time. It really doesn't tell you very much.
MysticNitekatt
- ram: 4GB
You're missing the point - this function isn't working when it should be.canuck wrote:I am in complete agreement with Kingston: testing before a burn is a total waste of time. It really doesn't tell you very much.
Now,anyone have any ideas why it's not working properly?
Kingston
- ram: 8 GB
Nobody here knows why it's not working. Since you found the problem, you must report it to Corel through formal channels.
MysticNitekatt
- ram: 4GB
I already did - I posted here to see if anyone encountered the same,or similar problems.Kingston wrote:Nobody here knows why it's not working. Since you found the problem, you must report it to Corel through formal channels.
MysticNitekatt
- ram: 4GB
They are still looking into this problem!
