template defaults to frame based
me3
motherboard: Gigabyte GA-MA69GM-S2H
processor: AMD Athlon 64 X2 4000+
ram: 2GB
Video Card: ATI 1250X
sound_card: Realtek HD audio
Hard_Drive_Capacity: 1TB
Monitor/Display Make & Model: Dell Ultrasharp 1704 FPV
Post by me3 »
I'm using the HQ 4:3 template in VS11+ but noticed it's defaulting to frame based. My clips are mpeg's BFF. Shouldn't this template be switched to bottom field first?
Hi everybody!
me3
ram: 2GB
Re: template defaults to frame based
Post by me3 »
My guess is that it' set to the frame-based default in case the user doesn't know if it's bff or tff. I've always just dropped compliant video into VS and have never experienced it's encoding. :lol:
Hi everybody!
Not sure I understand where you are using the HQ template.
I do not have VS 11 but other versions used this during either the capture process or the burn process
Share Create Disc
If you have a compliant Mpeg2 file then the option to Share Create Video File -Same as First Video would create the final video, burning this file to dvd would not render again, so the templates used in Project Settings would not be required.
If you do need to render (convert Mpeg files) then the default templates may not be suitable for you, in which case use the "custom" option to create your own.
But yes you are correct that the template uses Frame Based, at least VS 10 does, strange..........
and again not required if you use a compliant Mpeg file.
