Hi All,
Working on the trial x5 and have a random problem. Imported videos, 1280x720, randomly display a stutter in the audio track when playing in project mode. Play fine in clip mode. Play fine before import. Video plays fine. Also weirdly, if I stop and restart the video at the point of stutter, the stutter goes away. By random, I mean 4 out of 5 videos imported in the same format work fine and the place the stutter start seems random between clips that display the problem.
I am using the default settings of the download trial, though I have messed with the proxy, edit format, and other settings to no avail. I have installed the recent service pack.
System: Toshiba Laptop, Windows 7 Home Premium, dual core pentium 2.0 Hz, 3 gig installed memory.
Vidoes are captured with an android phone and properties are H,264, 24 bit, 1280 x720, MPG4, Interestingly the frame rate seems to vary between 19 and 26 fps., Audio is 44100Hz 16 bit stereo 96Kbps bitrate.
I've use x2 on a multimedia tower no problem but I've gone mobile. This problem makes the software almost unusable for me. The random nature of the glitch is crazy. Three or four out of five imports with same parameters (except the variable frame rate) work fine.
Any thoughts.
Be well and happy.
Sansvan
x5 Video auto stutter
Re: x5 Video auto stutter
When you render the project to a new video file, do you get the stutter in the new video?
erdna
- motherboard: Gigsbyte H81M
- processor: I7 4770
- ram: 16GB DDR3
- Video Card: Intel HD4600
- sound_card: Intel display audio
- Hard_Drive_Capacity: 1TB 7200rp
- Monitor/Display Make & Model: Panasonic TX32cx600e
How did you see that there is a variable framerate? or is it a variable refreshrate?
Yes the stutter does render.
Right click video clip gives me properties which show the "frame rate." Interestingly different videos from the same phone with the same settings have different frame rates.
Be well .
Vince
Be well .
Vince
erdna
- ram: 16GB DDR3
I think, if you have clips with different framerates, you will first have to render them separately to one of the standard (fixed) framerates.
Well that is the problem. It renders with the stutter so I cannot do as you suggest.
teknisyan
- processor: Intel Corel i5
- ram: 4 GB
- Hard_Drive_Capacity: 500 GB
Does the problem happens only to videos that are captured using your android phone or on all the videos? Have you updated the codecs on your laptop?
Here are some of the codecs that you may want to install.
RealPlayer: http://www.real.com/
DivX: http://www.divx.com/en/software/divx-plus/codec-pack
XviD: http://downloads.xvid.org/downloads/xvidcore-1.3.2.zip
Windows Media Player: http://windows.microsoft.com/en-US/wind ... dia-player or just download the Windows Encoder at http://www.microsoft.com/expression/pro ... rview.aspx
QuickTime: http://www.apple.com/quicktime/download/
Direct X: http://on-msn.com/aLrk0j (WinXP)
Direct X: http://www.microsoft.com/Windows/window ... tx-11.aspx
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
About Tech
About Sports
lubinajmrk
The same with my phonesansvan wrote:Hi All,
Any thoughts.
Be well and happy.
Sansvan
