installing new blue
housetrained56
- motherboard: gigaybyte
- processor: intal quad core
- ram: 8gig
- Video Card: zotac 1gig
- sound_card: intnal
- Hard_Drive_Capacity: 500git
- Monitor/Display Make & Model: thmalake
installing new blue
hi to the fourm iam needing some help advice on how to install newblue 3d transforamtion and 3d explosions to corel video studio x5 ultimate i have tried installing the in the vft_plug and the vfx_plug but are not showin they have been installed any help would be apperacatd thank you .... michael
Re: installing new blue
Welcome to the forums!
Can we assume you had VS switched off when you installed the New Blue effects, and that they don't appear when you switched the program back on? Have you tried it after rebooting the computer?
I confess that I am also having a little difficulty in installing a couple of the New Blue Video Essentials packs on the computer listed under my profile. Essentials I and II loaded correctly, but there is no Essentials III and only one from Essentials IV -- yet I used the same process to load all four packs. And I have of course rebooted and switched the program off and on. Strangely, all 4 packs installed perfectly on two other computers on which I have X5 loaded and they all show up. The only difference I can think of is that this computer uses Win 7 64 bit (like you) and the other two are 32 bit. But that does not really make sense. I will report back if I find a solution.
housetrained56
- ram: 8gig
hi thank you for some help yes had vs of and yes have tried rebooting thank you michael
housetrained56
- ram: 8gig
hi again just a foot note to add to post i have opend my corel this morning and in both teh vfx folder and the vft folder there are a lot of different file that are just jout not converted to the windowmediaaudio/video this is both folder hope this help thank you michael
teknisyan
- processor: Intel Corel i5
- ram: 4 GB
- Hard_Drive_Capacity: 500 GB
hello michael, do you have the older version of videostudio installed on your computer? It could be the same issue with Mercalli or Boris Graffiti plugins - http://corel.force.com/index/articles/e ... 4-Ultimate
You can just apply the steps from that link to your VS X5.
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
About Tech
About Sports
Have you tried "Resetting VideoStudio Pro X5 to its Factory Default Setting "
This will reset the library so if you need the contents, back it up first. Settings - Library Manager.
housetrained56
- ram: 8gig
thank you i will delet all and reinstall following the seteps will let u know in a day or two have a couple of busy days ahead thank you all again .......michael
housetrained56
- ram: 8gig
hi again to the fourm i have deleted corel x5 reinstalled and followed the instruction as per the page and still have no luck with instaling the new blue to corell thanks again for the help ............michael
We have Windows 7 64 bit installed on the laptop, however I have to run the program in XP compatibility mode other wise I have problems with the library content.
I guess there may be more problems as well.............
The library seems to be looking in the wrong C: / Programs file structure?
So have you tried running in XP compatibility mode.
Also I always run the programs with admin rights.
housetrained56
- ram: 8gig
hi to fourm again still no luck i formated anoth computer running 64 windows seven re installed x5 then reinstalled new blue explosions beore addin any update and fowllowed the instruction listed on boris no i have not tried the xp compability to ask a question regarding xp compability which program do i run in xp comability do i reinstall x5 and new blueusing the xp comability thank you to the fourm he advice is appericated iam sure iam not alone with this problem so may be all together we can all work out the problem and come up with an answer thank again .......... michael
I have to run Video Studio X5 program in compatibility mode. no need to re-install.
I have an X5 icon on the desktop that I use to launch the program.
Right click and select properties, the next window has a compatibility tab, I simply chose the XP option SP3 I think?
If it does not work or is causing more problems, just deselect it.
Maybe I should have asked earlier but can you say if these NewBlue filters are additional to the program, I mean have you purchased them? or are they the ones supplied free by Corel. I assume purchased?
Some users did notice that although filters were installed they did not show in the same sub folders within the FX library, this was a little strange but probably an operating system issue.
For instance some filters only showing in the "All" page.
