"Found an old file in the import" - Where are my images?
Bugs & Suggestions
jallis
operating_system: Linux
System_Drive: N/A
Post by jallis »
Suddenly, out of the blue, ASP fails to display a lot of my images. While browsing to the directory where the images are located in filesystem mode I see a lot of the following repeated for each images that is missing:
76168.58: Scanning file "/mnt/bilder/2012/IMG_7467.CR2"
76168.58: **** Found an old file in the import "/mnt/bilder/2012/IMG_7467.CR2"
76168.59: ContainerAsset::run() - unable to get info table item
76168.59: Deport master failed to get parent container
76168.63: Adding master versions
This just happened out of the blue, and the images are displayed correctly in the library where they are imported....
If I drag&drop the image from another program, into ASP, it will only open if it is copied from a directory without it's .xmp, so I'm guessing this is .xmp related...
Any help?
afx
System_Drive: N/A
Video Card: FirePro 4900
Re: "Found an old file in the import" - Where are my images?
Post by afx »
Nuke your cache. It is probably a bit out of whack.
cheers
afx
jallis
System_Drive: N/A
Post by jallis »
Thanks, that did the trick.
