New plugin LabTools 0.6
AfterShot Pro Plugins
roland65
operating_system: Linux
Post by roland65 »
Update 16/08/2012 - Renamed to LabTools
Update 25/06/2012 - Added new saturation control. It allows to increase / decrease image saturation by modifying the Lab a and b channels. Released new version 0.5.
Update 21/06/2012 - Fixed the version ID in the XML file and improved speed of the RGB <-> LAB conversion. Released new version 0.4.
Update 20/03/2012 - Fixed a bug that caused color artefacts. Released new version 0.3.
Update : I released today a new version (0.2) which works with the Lab L channel and so has much less color casts.
RB
I released today a new free plugin called SContrast. This is an implementation of the standard S curve for contrast increase or decrease. There are two parameters to adjust your image: contrast and lightness.
If you want to move this plugin within the tabs, its customToolsUI.txt keyword is : com.roland65.LabTools
Download the plugin here : http://www.aftershotpro.com/plugins/ind ... g=labtools
Have a nice day,
RB
nyukuri
ram: 4GB
Hard_Drive_Capacity: 500GB
Re: New plugin SContrast 0.1
Post by nyukuri »
Hi Roland,
Is this the same S-contrast as offered in Bez plugin?
roland65
Post by roland65 »
I think it uses the same theoretical basis, but the implementation is different. For example, SContrast works on the Lab L channel and uses fast math routines.
RB
nyukuri
ram: 4GB
Re: New plugin SContrast 0.2
Post by nyukuri »
ok, thank you
ferdinand-paris
motherboard: GA-X58A-UD3R
processor: 3.20 gigahertz Intel Core i7 960
ram: 4Gb
Video Card: NVIDIA GeForce 7300 GS
sound_card: Realtek High Definition Audio on-board
Hard_Drive_Capacity: 2500 Gb
Monitor/Display Make & Model: Eizo CG222W
Post by ferdinand-paris »
Bez for ASP also works on a luminosity channel, although it is L in either HCL or HSL, rather than running in the LAB stage in the processing pipe.
Sig contrast in Bez uses the sigmoidal formula, which necessitates using Exp and Ln functions, although on my main PC I don't really detect any processing lags. My netbook is a different matter, but then a lot of things are slow on it.
F_P
gareth
operating_system: Windows 8.1
motherboard: Acer Aspire TC-605
ram: 12Gb
Video Card: NVIDIA GeForce GTX 745
Hard_Drive_Capacity: a few TB
Monitor/Display Make & Model: AOC 2369M sRGB
Post by gareth »
On my ORF files, enabling this plugin - even with setting 0,0 - adds lots of brightly coloured noise to the image.
Very pretty but not what I want to achieve :-)
ex-Bibble - mostly OLY E-510 and E-M5 + Win 8
roland65
Post by roland65 »
Congratulations, you've found a bug ;-)
I fixed it and uploaded a new version of the plugin (version 0.3) to the Corel plugin site (http://www.aftershotpro.com/plugins/?plug=scontrast)
Could you test it?
Thanks,
RB
WilsonC
Monitor/Display Make & Model: Samsung SA300
Re: New plugin SContrast 0.3
Post by WilsonC »
Dang, you are fast! When I went to install 0.3 Aftershot still believes it is 0.2....so it asks if it should replace 0.2 instead of upgrade it.
-Christopher
gareth
ram: 12Gb
Post by gareth »
That's fixed it ... no more speckles and the colour stability looks pretty good ( to me - though I am not a pro )
The Help shows 0.3 but your install file needs fixing to be 0.3.
I have been using my own sigma curves but I really miss the 'use Lab Curves' B5 plugin
( any chance of an ASP 'use lab curves' as you are working in that area - I used to like that for solarisation effects ! ) :wink:
roland65
Post by roland65 »
WilsonC wrote:Dang, you are fast! When I went to install 0.3 Aftershot still believes it is 0.2....so it asks if it should replace 0.2 instead of upgrade it.
Probably I was too fast ;-) because I forgot to update the version ID in the XML file.
Anyway, in between I released a new version (0.4) with this glitch fixed and also some improvement in the RGB <-> LAB conversion speed.
This one should stay for a while...
RB
roland65
Post by roland65 »
gareth wrote: I have been using my own sigma curves but I really miss the 'use Lab Curves' B5 plugin
I remember there was a LabCurves plugin from Thomas Baruchel, but I don't know what it was supposed to do. Could you give me some explanations about it?
RB
afx
System_Drive: N/A
Video Card: FirePro 4900
Post by afx »
roland65 wrote:I remember there was a LabCurves plugin from Thomas Baruchel, but I don't know what it was supposed to do. Could you give me some explanations about it?
RB
Source can be found here:
http://afximages.com/stuff/plugins/Baru ... ources.tgz
cheers
afx
roland65
Post by roland65 »
afx wrote:Source can be found here:
Yes, I have these sources and I have looked to the code. Here is what I understand.
There are two functions and one parameter called amp.
The first function converts RGB -> Lab and then applied these formulas:
R=65535*L/100
G=65335/(2*amp)*(a+amp)
B=65535/(2*amp)*(b+amp)
The other function applies these formulas :
L= R/65535*100
a=G/65535*(2*amp)-amp
b=B/65535*(2*amp)-amp
and then converts Lab -> RGB
It is not clear to me where exactly in the pipe these function are called, but I'm sure the first one is called before the second one. I don't know what processing is supposed to be done between the two.
If I understand well, the amp parameter shifts the a and b channels, but after that they get the same value as before? If someone understands what is done here...
RB
gareth
ram: 12Gb
Re: New plugin SContrast 0.4
Post by gareth »
I shall describe from a user perspective ( ie ignorance :) )
The effect is that when enabled, the red channel on the Curves window represents L and dragging points on the red curve results in a suitable change to the value of L
I have used it with a red sigmoid curve for contrast effects and an M or W shape to introduce a solarisation look alike.
The other two channels are more difficult to drag on the screen but do indeed affect a and b.
I guess the two formulae convert from the current state to screen display coordinates ( which then represents Lab ) [ then the in-out mapping from the screen is applied here ] and back again to reflect changes to the red line back into a change to actual values. So they should, I think wrap the place where Curves are applied to the image.
roland65
Post by roland65 »
OK, I understand now how it works. However, I'm not sure about the purpose of the amp (amplitude) parameter. I think it controls the amount of the curve effects that are applied, am I correct? Do you think this parameter is important?
RB
