HELP!
I want to connect plugins, so that changes in one will effect the other. I do understand for the most part the UI syntax (sender, receiver, signal), but HOW do I get the HINTS for a specific slider, checkbox etc?
<hints>
<hint type="sourcelabel" >
<x>143</x>
<y>46</y>
</hint>
<hint type="destinationlabel" >
<x>143</x>
<y>94</y>
</hint>
</hints>
These hints for source and destination, where can I get them?
Thanks for your help
-nyukuri
HELP! connecting plugins (hints 4 source and destination?)
afx
- System_Drive: N/A
- Video Card: FirePro 4900
Re: HELP! connecting plugins (hints 4 source and destination
I do not think you can do this from the UI files, you would need to set up the signal handling parts in the code to support this.
cheers
afx
PS: I took the liberty to move this to the right subforum.
cheers
afx
nyukuri
- ram: 4GB
- Hard_Drive_Capacity: 500GB
thank you, that's what I feared!
so I will rely on the goodwill of the authors to provide me with that info or even source code...
nyukuri
nyukuri
